Suspension - Mustang Evolution
Old 01-23-2014, 10:45 AM   #1
Sgt_Syke's Avatar
Suspension
What suspension set up do you recommend for dd fox? T5 with 3.73's
Sgt_Syke is offline   Reply With Quote
Old 01-23-2014, 11:30 AM   #2
89GTstanger's Avatar
This is what's on mine. I love it!! It does have a stiff ride tho which I dont mind but my wife hates it...lol
http://www.maximummotorsports.com/19...Box-P1031.aspx
You can't lose if you put God first!
1989 LX, 306 with TF top end kit, Anderson N-21 cam, TKO 600 trans with steel splatter shield,full Maximum Motorsports Mustang maximum Grip box, Detroit locker rear end with 31 spline Moser axles. Staggered wheels with Nitto 555 315/35/17 out back.
89GTstanger is offline   Reply With Quote
Old 01-23-2014, 01:07 PM   #3
ALMOST STOCK's Avatar
I went with the Maximum Motorsports Strut tower brace, 4 point K member Brace, C/C plates, Pan Hard bar, Sub frame connectors, Lower controls, the Upper control arms are the Ford solid axel along with the bushings. I also went with the H&R Sport Springs to lower my car 1inch and I'm using Bilstein Struts and Shocks.
The handling is great and the ride is firm but not stiff and bone jarring.
ALMOST STOCK is offline   Reply With Quote
Old 01-23-2014, 02:41 PM   #4
Roguestang's Avatar
Can't go wrong with MM parts. If you're buying everything separate, don't forget sub frame connectors!
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 01-23-2014, 06:29 PM   #5
Sgt_Syke's Avatar
Ok, after looking at link, yikes!! $5k just on suspension. I've only got about $1k set aside for this, so where should I start?
Old 01-23-2014, 06:32 PM   #6
Roguestang's Avatar
Subframe connectors (weld in)
MM lower control arms
your choice of springs
mm CC plates
and new shocks and struts.
Oh and new bushings....
Old 01-23-2014, 06:52 PM   #7
Lol...yeah I only gave 4200 for the car...lol. told you I got a good deal on it...lol
Old 01-23-2014, 09:00 PM   #8
And that is why I took the route that I did when I bought my suspension parts ... I didn't have 5K to spend either.
Old 01-24-2014, 11:41 AM   #9
Sgt_Syke's Avatar
What did that run you?
Old 01-24-2014, 08:16 PM   #10
Doing a quick check with the receipts I still have from 2000 when I did this it's a little under $2,000
Old 01-25-2014, 02:14 PM   #11
Sgt_Syke's Avatar
I haven't done much research yet into the suspension, but is most of that stuff bolt on that I can do in garage a little at a time? Subframes will be welded, but other than that is the rest pretty simple?
Old 01-25-2014, 02:21 PM   #12
Yes everything I did was a bolt on that I did myself, the only welding that was required was the Sub Frame Connectors.
Old 01-25-2014, 03:38 PM   #13
Sgt_Syke's Avatar
Sweet ill start with subframes and then see how much $ I have left for other suspension stuff...I'll get what I can, then I'll have to wait for more $ to flow in.
Old 01-25-2014, 05:37 PM   #14
There's always that Income Tax Return that needs to used ..
Old 01-25-2014, 05:43 PM   #15
Roguestang's Avatar
Same here.
Old 01-25-2014, 05:47 PM   #16
Roguestang's Avatar
List out in order what you plan on getting. This was mine.
1. Sfc's
2. Springs with shocks and struts
3. Lca's (if you get uca's get spherical bushings
4. Strut tower brace
5. Panhard and sway bars
6. Tubular k member (to use stock a arms)
Old 01-26-2014, 06:37 PM   #17
foxbox's Avatar
1. Sfc's
What k member were you thinking about installing? Also I dont hear alot about upgrading sway bars on 79-95's, are they worth it for the street? I only ask because im also interested in these upgrades as well.
foxbox is offline   Reply With Quote
Old 01-26-2014, 07:15 PM   #18
Roguestang's Avatar
I believe UPR and team Z allow you to use the stock arms with theirs. You can always add the tubular ones down the road. And for a DD street car, probably not worth it to do the sway bars. But if you autoX it, it would be a good idea.
Old 01-27-2014, 07:32 PM   #19
foxbox's Avatar
Yeah I was looking at a few different k members and some of them say you can use stock control arms however the reviews said they were having clearance issues. It seems like each brand has their own suspension geometry. I think ill probably wait until I can afford the mm k member and arms if I go that route. Right now im debating on getting the steeda bumpsteer kit for my 1.5” drop, im still confused if I actually need it or not
Old 01-27-2014, 07:41 PM   #20
You can't go wrong with Maximum Motorsports. thumb:
Old 01-27-2014, 09:00 PM   #21
Roguestang's Avatar
Correct. If you use the stock a arms, your tires will move back around an inch or so IIRC. If your running the stock size, it shouldn't be an issue. But then there's the old adage of doimg it right the first time. ...lol
Old 01-27-2014, 09:02 PM   #22
Roguestang's Avatar
Agreed. Although the Team Z and UPR not to mention QA1 are all Just as good. I have heard some say they had fitment issues with the Team Z when theu forst came out, but that was a while ago.
« T5 | Project Notch »
Air Suspension MythlinMasterdo General Mustang Discussion 4 01-26-2014 01:17 PM
Gears or Suspension? Soccerluvr4 1996-2004 Mustang GT 29 04-30-2013 10:41 PM
Suspension Write Ups ! Slow4V 1996-2004 Mustang GT 8 04-15-2013 08:51 PM
NMRA "Super 'Stang" rules and regulations rebeltx At the Track 4 03-06-2013 11:02 AM
New Suspension Changes Nice Pony 2005-2010 V6 Mustang 5 02-05-2013 03:31 PM
06:30 AM
