89 GT cranks every time but won't start MOST TIMES! HELP!! - Page 2 - Mustang Evolution
Old 01-28-2014, 09:54 AM   #36
Liebert91stang's Avatar
Check voltage on pins that plug into tfi comming from coil
Liebert91stang is offline   Reply With Quote
Old 01-28-2014, 10:00 AM   #37
Red89's Avatar
Don't mean to sound lost, but I am. Probably fried my brain thinking about this for the past 10 days endlessly.
How would I do that. Pins in the TPI, harness, coil?
If you get time later can you break it down a bit. Just not getting it. Probably having a brain fart.
---------- Post added at 12:00 PM ---------- Previous post was at 11:59 AM ----------
Red89 is offline   Reply With Quote
Old 01-28-2014, 10:09 AM   #38
I went back and looked at your troubleshooting to see if I missed something.if there isn't spark at plugs it probably ignition module
Old 01-28-2014, 10:19 AM   #39
http://www.ehow.com/how_4422228_chec...on-module.html
Old 01-28-2014, 10:20 AM   #40
Red89's Avatar
And I replaced the ignition switch 2x's already.
Think I am about out of ideas. She don't crank tonight after the TPI and checking ground and pins tomorrow I call the shop
Old 01-28-2014, 10:26 AM   #41
Only other thing is check wires for burn marks or loose connections.other than that I'm out of ideas.keep me posted when you find problem
Old 01-28-2014, 11:07 AM   #42
Cps will cause no spark.about the only thing you haven't checked.it down at bottom pulley by crankshaft
Old 01-28-2014, 03:19 PM   #43
Red89's Avatar
I don't think the Fox bodies have a CPS, think the PIP in the distributor is the position sensor.
Old 01-28-2014, 04:35 PM   #44
ALMOST STOCK's Avatar
You are correct.
ALMOST STOCK is offline   Reply With Quote
GT or customize my v6 xhgwx Pre-2005 V6 Mustang 37 12-23-2011 01:17 PM
'12 GT C/S New Rim Time, Opinions! SilverBullet12 2011-2014 Mustang GT 15 12-11-2011 01:42 PM
Cobra will not start drusmith General Mustang Discussion 14 11-28-2011 06:06 PM
First time racing at the track... skyline247 At the Track 14 10-06-2011 09:55 PM
2006 GT 350 theivanoff 2005-2010 Mustang GT 15 09-20-2011 05:16 PM
08:32 AM
