fox has a hick up(hesitation) - Mustang Evolution
Old 01-25-2014, 12:51 PM   #1
89 5.0 stang's Avatar
When my car gets warm it will have a hesitation issue...around 1500rpm to 2800rpm.
Its hard to explain its almost like a "hick-up". ill drive to work in the mornings and its fine (not that long of a commute), but after i get off work and go to my dads shop then go home it will do it.....it likes to do it i the freeway in 5th or 4th gear around 1800rpm but if i put my foot in it it'll run like a champ. However if i put my foot in it and pass through that rpm range it may or may not do it....it will do it in any almost any gear. But will idle PERFECT. Things I've changed: Coil, Cap and Rotor, spark plugs(around 3 months ago) and no it didn't do it after i changed them...its been getting worse car has no mods except exhaust. 165,000 miles. I've been told it could be a Vacume line, spark plug wires, a sensor....Help
89 5.0 stang is offline   Reply With Quote
Old 01-25-2014, 05:07 PM   #2
92coupe's Avatar
Check all your plug wires for a break in one. Maybe one that was up against your exhaust and melted?
92coupe is offline   Reply With Quote
Old 01-26-2014, 04:52 AM   #3
mustangmania91's Avatar
I'd replace the TFI module on your distributor
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
mustangmania91 is offline   Reply With Quote
Old 01-26-2014, 09:51 PM   #4
Minus2380's Avatar
Try cleaning the maf sensor.
Minus2380 is offline   Reply With Quote
Old 02-01-2014, 01:00 PM   #5
I have cleaned MAF sensor,(it looked clean when i took it out) I will be changing the EFI to my friends stock one and see if it is that. Thanks for your help guys.
Old 02-02-2014, 12:57 PM   #6
The TFI module goes on your distributor. You can buy a stock one at any aftermarket store for under $40. Mine would be going fine down the highway and out of nowhere act like it missed or like the clutch had slipped. I replaced it and hasnt happened since
Getting rid of SN-95 for a Fox. zhill29 1979-1995 Mustang GT 4 01-18-2014 11:16 AM
Fox Brett Greene 1979-1995 Mustang GT 18 12-28-2011 01:25 PM
96 347 Stroker for My 302 Fox? Qwik Four Six Pictures and Videos 5 11-25-2011 04:37 PM
best 4 eyed fox. 82stang224 1979-1995 Mustang GT 16 08-06-2011 09:08 PM
opinions on color for 88 fox 04TRV6 1979-1995 Mustang GT 39 07-08-2011 12:30 AM
07:59 AM
