GT40 vs AFR vs E7 - Mustang Evolution
Old 02-03-2014, 10:10 AM   #1
Slow4V's Avatar
GT40 vs AFR vs E7
Well me and my dad decided on building a 347 .. Mexican block
Now we are ordering the stroker kit,
I wanted to get some good heads ..would E7 heads with a stage 3 port/polish job, good rockers / springs do me any good?
Same goes for GT40P heads ..
Or is AFR supreme .. They are just expensive
Old 02-03-2014, 10:34 AM   #2
2300turboford's Avatar
408 Windsor!!!!!!!!!!!!!!!!
An yes afr will still flow better
---------- Post added at 12:34 PM ---------- Previous post was at 12:33 PM ----------
Don't waste your time with a 302 based build
Old 02-03-2014, 01:20 PM   #3
Slow4V's Avatar
I've seen multiple 347 strokers running 10s-11s ?
Old 02-03-2014, 02:16 PM   #4
89GTstanger's Avatar
AFR by far. The only head that can compete is Trick Flow twisted wedge. 347 is a good build but I would invest in an aftermarket block. I like DSS since I've had a lot of friends use their parts in the past week with no issues. Their blocks come machined for stroker kits and aren't price to bad either. They have different levels so you can pick the level you want for the HP your looking to hopefully run.
You can't lose if you put God first!
1989 LX, 306 with TF top end kit, Anderson N-21 cam, TKO 600 trans with steel splatter shield,full Maximum Motorsports Mustang maximum Grip box, Detroit locker rear end with 31 spline Moser axles. Staggered wheels with Nitto 555 315/35/17 out back.
89GTstanger is offline   Reply With Quote
Old 02-03-2014, 08:29 PM   #5
Slow4V's Avatar
Thanks , I will look into that..
Does anyone recommend a good cam?
Or do you need to know my rotating assembly
Old 02-03-2014, 08:37 PM   #6
Slow4V's Avatar
Old 02-03-2014, 08:55 PM   #7
My personal favorite is lunati but I do like the F-303 cam because it has a nice lope. As for specs I would call whom ever your going to get the cam from and tell them what you want and see what they have
Old 02-03-2014, 09:16 PM   #8
You need to know what head and rotating assembly your using
gt40 internal or external _MrFoxbody_ 1979-1995 Mustang GT 2 05-07-2013 03:45 PM
Looking for a good AFR gauge CrimsonGT 1996-2004 Mustang GT 5 01-26-2013 10:23 PM
Best year to get of gt40 intake tbonestang 1979-1995 Mustang GT 3 12-28-2011 10:08 PM
Will GT40 Heads Handle A Big Cam?? 90Stang_5.0 1979-1995 Mustang GT 27 11-02-2011 03:12 AM
E7 heads or Gt40 heads? Qwik Four Six 1979-1995 Mustang GT 18 10-29-2011 09:59 PM
04:30 PM
