Thanks for the help - Mustang Evolution
Old 02-06-2014, 05:50 AM   #1
94CobraUSMC's Avatar
Thanks for the help
This thread is to tell everyone thanks for the advice torwards my car and so you can see the route I went. The cobra is still being put together but the last parts came in today. Here's the parts
Hardened push rods ford racing
Pedestal Rockers ford racing
Valves ford racing
Steeda 19 cam
K&n cold air kit
Bbk long tube ceramic headers
Bbk x pipe
Magnaflow magnapacks
Eibach sport springs
Eibach shocks/struts
Eibach sway bars
Qa1 camber caster plates
J&m upper control arms
Steeda adjustable lower control arms
Steeda bumpsteer kit
Borg Warner fuel pump
Ford racing oil and water pump
Ford racing smog pump delete
All new bushings and bearings up front
I think that's everything again guys thanks for your help I know I coulda went for more performance but this was just a rebuild since were about to hit 100000 miles
94CobraUSMC is offline   Reply With Quote
Old 02-06-2014, 06:43 AM   #2
Name:	ImageUploadedByMustang Evolution1391694179.947709.jpg
ID:	147161 last picture before surgery lol
Name:	ImageUploadedByMustang Evolution1391694218.026947.jpg
ID:	147162 last part to arrive
Old 02-06-2014, 11:15 AM   #3
List looks really good. Only thing I don't like are the aftermarket upper control arms. I'd return them and just get new rubber bushings for the stockers.
At any rate keep us posted on the progress and let us know how it all turns out. The 94/95 Cobra is one of my favorites and may be the best bang for the buck Mustang currently out there.
Old 02-06-2014, 11:24 AM   #4
Mosified's Avatar
+1 Heck ya!! My car would be extremely boring -_- without M.E.
Old 02-08-2014, 09:00 AM   #5
Ha yea mines nothing great but it's mine so I love it
Old 02-08-2014, 09:06 AM   #6
You helped a bunch and I was told getting after market uppers would help wheel hop we'll see how she does, but after I removed the quad shock to stuff 315's the wheel hop got pretty bad I'll keep you guys posted April 12 iOS the first time I'll get to drive her myself. Sottydoesntkniw you were a ton of help even though I know I didn't do exactly what you said I still read it and you were my main source and always there to help on here
Old 02-08-2014, 02:31 PM   #7
The lower control arms will help the wheel hop a ton, the uppers will help with windup but the suspension can get VERY bound up going around corners and will be hell on your torque boxes. This is why I would not recommend tubular uppers. Going around a corner with the stock uppers the stock stamped ones will flex and take the stress off the torque boxes. Yeah the deflection is not good and hurts your handling but that's the inherent problem with the stock 4 link setup.
The REAL solution to this problem is a torque arm/panhard bar setup (or watts link in place of the panhard bar). Eliminates the UCAs completely, torque arm prevents windup completely/is rock solid and the panhard bar or watts link setup keeps your rear end properly centered. The watts link is more expensive but better because it keeps the rear end totally centered throughout the entire range of rear suspension travel. By its very nature the panhard bar setup will move the rear slightly to the left or right as the suspension loads and unloads but for a street car its not going to be noticeable.
You can also go to an IRS out back but you need to install a $700 bushing kit in place of all the compliant rubber stuff right off the bat or you WILL get wheel hop and that can snap halfshafts with enough power...
Old 02-12-2014, 01:44 AM   #8
Thanks Scotty if I was going to be tearing up the track all that often me and pops were talking about going with the watta link but I don't think I'm at that level were I need at that right now in the future it's very possible but so is a 331 stroker thanks again
Oh yea 2 parts I forgot
Exedy stage 2 clutch
Ford racing spec flywheel
Old 03-02-2014, 07:46 AM   #9
Updated pictures Click image for larger version
Name:	ImageUploadedByMustang Evolution1393771588.868891.jpg
ID:	149430Click image for larger version
Name:	ImageUploadedByMustang Evolution1393771600.887576.jpg
ID:	149431Click image for larger version
Name:	ImageUploadedByMustang Evolution1393771614.019602.jpg
Old 03-02-2014, 10:27 AM   #10
Nice, progress. What are you doing transmission wise? A T-5 is only going to hold up so long behind a stroker. If you are staying 5 speed I would highly, HIGHLY suggest looking over at Astro Performance and their A-5 transmissions. Conservatively rated at 585 ft lbs for the strongest one and they shift like a stock T-5 (like a hot knife through butter). Everyone says "oh my trans shifts like butter" but unless you've driven a brand new fresh T-5 you don't know what a smooth shifting trans is. Too bad they are so weak in stock form.
And if you are doing a Magnum I'd also take a look at Astro's Magnums. He does a few extra mods to make sure they have no clearance issues and can also go through the new Magnum trans and do a few tweaks if you want. It will cost you, but if you are buying a Magnum and planning to beat on it I'd say its worth considering.
Old 03-11-2014, 07:33 AM   #11
Thank you Scotty that would all be way in the future but I'm thinking of a g force kit for the t-5 soon just for now. It probably doesn't need it but I definitely don't need a new trans for what I have right now.
Old 03-11-2014, 08:53 PM   #12
Astro is stronger than G-force no matter what anyone tells you. The Astro gears are physically bigger.
Old 03-11-2014, 08:54 PM   #13
But which is cheaper? I believe you I just don't I have the need for that at the moment. Know what I'm saying?
Old 03-12-2014, 11:44 AM   #14
IIRC the prices are similar. Astroperformance.com - Your Manual Drivetrain Specialist
If you are looking at a G-force now not sure why you wouldn't be looking at the Astro as well. And as I said, you are GOING to get ppl telling you they are the same or that G-force is just as strong. Its either lies or ignorance, I've seen the gears side by side and just with the naked eye you can pick out the Astro gear.
Old 03-12-2014, 03:40 PM   #15
Hmmm you have a valid point I will definitely look into it
Old 03-16-2014, 09:10 AM   #16
Update engine is back in dad's gonna start putting it all back together then should have exhaust video. An only 26 days until I'm home and get my baby back. Click image for larger version
Name:	ImageUploadedByMustang Evolution1394982631.906915.jpg
ID:	150828Click image for larger version
Name:	ImageUploadedByMustang Evolution1394982645.618333.jpg
Old 03-20-2014, 04:49 PM   #17
More new picturesClick image for larger version
Name:	ImageUploadedByMustang Evolution1395355712.137386.jpg
ID:	151300Click image for larger version
Name:	ImageUploadedByMustang Evolution1395355725.699455.jpg
ID:	151301Click image for larger version
Name:	ImageUploadedByMustang Evolution1395355752.919474.jpg
Old 04-08-2014, 01:53 AM   #18
Final update the beast is alive short exhaust clip on my face book
Long tubes
O/r x
Magnapacks
https://www.facebook.com/jeremiah.d....52296635190239
11:51 AM
