95 cam install - Page 3 - Mustang Evolution
Old 03-03-2014, 02:39 PM   #71
Evolution's Avatar
Never heard back from A.M so I went to a local mustang shop and talked to them, ended up getting the trickflow stage 1 and I'll be putting it in as soon as it gets nice out
Evolution is offline   Reply With Quote
Old 03-03-2014, 03:02 PM   #72
89GTstanger's Avatar
That works I guess. This is the cam I have picked out for my car... Lunati , part number # 10310515LK. Has a rough idle. I will have to make sure that it will work with my 1.7 RR and pushrods. I think I will be measuring these one. Its a flat tappet cam and not a roller. But once I put it in I'll be getting a dyno tune also. That will be bada**
Sent from my XT1060 using Mustang Evolution mobile app
You can't lose if you put God first!
1989 LX, 306 with TF top end kit, Anderson N-21 cam, TKO 600 trans with steel splatter shield,full Maximum Motorsports Mustang maximum Grip box, Detroit locker rear end with 31 spline Moser axles. Staggered wheels with Nitto 555 315/35/17 out back.
89GTstanger is offline   Reply With Quote
Old 03-03-2014, 03:10 PM   #73
Evolution's Avatar
Oh nice, what's the difference between a roller cam and the one your getting?
Old 03-03-2014, 03:24 PM   #74
Evolution's Avatar
Old 03-03-2014, 03:28 PM   #75
Well the one I'm getting doesn't have roller lifters. The lifters have a flat bottom that rides on the cam itself. It's still hydraulic, just not a roller.
Old 03-03-2014, 04:22 PM   #76
Evolution's Avatar
Oh ok I get it. I was thinking about port and polish my gt-40 intake and maybe my gt-40 heads, is it worth it? And is it pricey?
Old 03-03-2014, 04:23 PM   #77
Its worth it but Idk price. I did my own in the past.
Old 03-03-2014, 04:28 PM   #78
Evolution's Avatar
How did you do that ?
Old 03-03-2014, 06:15 PM   #79
5.oh's Avatar
I've heard of good gains from the lower. Prices vary in different states. Don't know how much but the bottoms worth it. The top flows around 200cfm I believe and when you port the bottom you'll be matching the top to the bottom. So it'll all flow 200cfm.
Sent from my SM-N900T using Mustang Evolution mobile app
5.oh is offline   Reply With Quote
Old 03-05-2014, 10:08 PM   #80
5.oh's Avatar
You can use a dremell. That's how people self port
Old 03-05-2014, 10:19 PM   #81
To hard to try to explain how to do it. You use Tue gasket that comes in the kit and a scribe to mark the outline and an angle grinder with the prober bits. You can use a drill or dremell also
Old 03-06-2014, 08:59 AM   #82
Evolution's Avatar
So just a dremmell and a regular sanding bit?
Old 03-06-2014, 12:10 PM   #83
5.oh's Avatar
Look up porting on google. There a couple sites for the 302 that'll show you how to gasket match.
Old 03-06-2014, 12:13 PM   #84
Not a regular bit. You need carbide bits. I agree, you tube and you'll get a good idea of what to do and what you'll need
Old 03-17-2014, 12:54 AM   #85
Evolution's Avatar
Looking at getting springs, I have the gt-40x heads, do I need specific springs for my heads? Or can I use just basic comp can valve springs?
Old 03-18-2014, 03:37 PM   #86
You can use any springs so long as the have the same outer diameter and spring pressure for the cam your installing.
Sent from my SM-N900V using Mustang Evolution mobile app
Old 03-18-2014, 03:42 PM   #87
Evolution's Avatar
It's a very simple cam so I'm hoping just the comp springs from A.M would work, I believe they are the same as the stock springs for diameter and such, they are just stronger as far as I know. Just hoping they'd fit with my heads.
Old 03-21-2014, 02:55 AM   #88
Evolution's Avatar
I have not installed the cam yet as weather has been terrible lately, but I have been thinking about doing a return and getting trickflow stage 2 cam, I'd be purchasing comp cam springs and hardened pushrods along with injectors, maf and a fuel pump. Will I need to consider longer pushrods and such or is the lift not that substantial?
Old 03-22-2014, 09:53 PM   #89
5.oh's Avatar
Compare the specs for the cam. Anytime you get a new came you want to measure for pushrod length.
Old 03-22-2014, 10:08 PM   #90
5.oh's Avatar
Got you a link for a really simple video that also helped me out lol
---------- Post added at 10:08 PM ---------- Previous post was at 10:08 PM ----------
Old 03-23-2014, 02:21 AM   #91
Evolution's Avatar
Pretty good video there, quite the tool aswell too. I guess I'll have to see then when I've got the valve covers off and intake and such and I can measure to see if I've got the right lengths for my cam or even for a stage 2.
Old 03-23-2014, 11:30 AM   #92
5.oh's Avatar
Yes sir!! Good luck. Let me know how it goes
Old 03-23-2014, 03:00 PM   #93
Evolution's Avatar
Awesome thanks, just snowed as of the first day of spring so I won't be doing it for a while until it gets nice out.
Old 03-28-2014, 08:33 PM   #94
5.oh's Avatar
Okay. Looking to do a cam in my car. So I finally know what cam I got, and can put proper push rods in it and springs. You planning on putting heads in too?
Old 03-28-2014, 09:01 PM   #95
Evolution's Avatar
I've got a bunch done to my car already, it has gt-40x heads in it, I'm planning on buying hardened push rods, roller lifters and comp cam valve springs. I've also already got roller rockers.
Old 03-28-2014, 10:26 PM   #96
5.oh's Avatar
Ohh okay! Just seeing cause I was planning on doing heads (gt40) when I do the cam.
Old 03-29-2014, 12:26 AM   #97
Evolution's Avatar
I probably would if I didn't have heads, I mean while your there if you've got the money you may aswell do it. What cam are you putting in?
Old 03-29-2014, 11:09 AM   #98
5.oh's Avatar
Thinking of the stage 1 or e303. Tfs stage 2 has a lot of lift..
Old 03-29-2014, 11:16 AM   #99
Evolution's Avatar
I've got stage 1 and I've looked up lots of videos, sounds good and I've heard it's a good cam. I was going to go with an alphabet cam but it was easier to do trickflow cause I didn't need to upgrade any valve train, but I'm going to upgrade it anyways cause I'm gonna throw a supercharger on it eventually. I was going to do the e303 aswell
Old 03-30-2014, 03:54 AM   #100
Evolution's Avatar
Would this bolt up to my 95? Click image for larger version
Name:	ImageUploadedByMustang Evolution1396173246.322128.jpg
Not sure how different the fox 302 are.
Old 03-30-2014, 08:02 AM   #101
slade95gt's Avatar
Possibly but it's missing a lot
slade95gt is offline   Reply With Quote
Old 03-30-2014, 09:05 AM   #102
slade95gt's Avatar
Main differences are headers and Intake you'll have to do away with that stupid elbow they put in the 94 and 95's
Old 03-30-2014, 09:40 AM   #103
5.oh's Avatar
Yeah I'm kinda stuck between witch one .. and that should work. You have a 5.0 rite? Same motor if it is just different placement of little things. It'll work. Specially since it's not like a turdo where you have to run vehicle specific piping
Old 03-30-2014, 09:43 AM   #104
5.oh's Avatar
That's the vortex super charger. He don't have to do anything with headers. Intake might be a different story
---------- Post added at 10:43 AM ---------- Previous post was at 10:42 AM ----------
That runs the crank. Not of exhaust
Old 03-30-2014, 10:45 AM   #105
slade95gt's Avatar
I was just stating differences between fox body 5.0 and 94 and 95 5.0
4.2 swap build list mummert_96v6 Pre-2005 V6 Mustang 34 11-25-2013 01:21 PM
97 GT 32V Swap 95v686gt 1996-2004 Mustang GT 537 09-27-2013 02:32 PM
Cam Install Price xhgwx Pre-2005 V6 Mustang 17 08-22-2012 05:08 AM
Good Information Thread. ESG642T Pre-2005 V6 Mustang 10 01-13-2012 08:00 AM
Cam install... stangstar92 1996-2004 Mustang GT 15 07-14-2011 10:34 AM
08:21 AM
