Aod swap to T-5 - Mustang Evolution
Old 02-11-2014, 08:07 PM   #1
FordRacer_51's Avatar
Aod swap to T-5
Ok I just bought a 1991 gt and im doing a T-5 swap and im wondering if I need to swap the ecu and also how to bypass the neutral safty switch and make the reverse lights work? Thanks
Sent from my SCH-I915 using Mustang Evolution mobile app
FordRacer_51 is offline   Reply With Quote
Old 02-11-2014, 08:41 PM   #2
Roguestang's Avatar
I did this on my 90' GT. You dont have to swap the ecu, the stock one will work fine. And unless you want it, don't worry about the neutral safety switch. I always keep my car in neutral when parked so I have no worries about it jumping in gear. I took the reverse lights plug, cut the plug off, and hooked the wires directly to where they would plug into on the t5. If your unsure which goes where, just hook em up, and if they dont work, swap the wires. There are plenty of write ups on this swap too. I think installing the clutch pedal was the hardest part.
Sent from my GT-P3113 using Mustang Evolution mobile app
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 02-11-2014, 08:46 PM   #3
Ive done it on my sn 95. I had wire 2 wires together for it to start. But your sayin I haveto do nothing?
Old 02-11-2014, 08:56 PM   #4
baddbradd's Avatar
I never swapped my ecu either. Back in the olden day, thw aod comp. was preferred, what I read anyway.
2001 coupe
baddbradd is offline   Reply With Quote
Old 02-11-2014, 09:22 PM   #5
Roguestang's Avatar
The reverse lights and neutral safety switch are two separate things. If you don't care if the car will start without the clutch pedal being pressed, then don't worry about it. If you do, then you have to get the saftey switch, and plug it in. I didn't care, so I just left it as is.
As for the reverse lights, I hacked into the stock harnes and just hard wired it directly to the t5. Its just two wires. It should be similar to the sn95, but I haven't done it on one of those, so I'm not 100% sure its the same way. If you have the t5 harness, you could obviously use that also.
Old 02-14-2014, 12:09 PM   #6
Pretty much but I learend a long time ago to NEVER leave your car in neutral when parked. E-brake fails and you are on any sort of an incline and off she goes. I leave mine in 4th and if I'm on a level surface I don't use the e-brake. Saves wear and tear on the e-brake cable.
Old 02-14-2014, 01:27 PM   #7
Roguestang's Avatar
Yeah you make a good point. But here in florida there is no such thing as an incline lol
Old 02-14-2014, 01:50 PM   #8
Roguestang's Avatar
And it there is a hill, i'll put it in 1st. Muscle memory pretty much makes me push a clutch in on start up anyways. Even in automatics...lol
Old 02-14-2014, 01:53 PM   #9
Lol yeah when I'm DDing a stick shift for awhile and get into an auto I always go for the phantom clutch.
2011 3.7L V6 6R80 to MT-82 swap completed 3.7Cyclone 2011-2014 V6 Mustang 17 12-24-2014 12:00 AM
4 Banger 351w Swap zhill29 1979-1995 Mustang GT 7 01-20-2014 10:22 PM
Motor swap Wmcgrattan General Car Discussion 35 12-05-2012 04:36 AM
AOD to T5 Swap & Idle, Bucking Issues Trojan Horse 1979-1995 Mustang GT 5 02-06-2012 09:47 AM
5.0 HO swap gc19662007 1979-1995 Mustang GT 16 11-25-2011 08:33 PM
02:32 PM
