Intermittent Start - Mustang Evolution
Old 02-12-2014, 03:35 PM   #1
Sgt_Syke's Avatar
Intermittent Start
About a year ago when I bought the car I was having issues with car not starting when I turned the key...battery, solenoid, were good so I replaced ignition switch as that is a common problem on mustangs. For about the last year it was fine, now two days ago it started doing it again. Nothing else was changed. It's an 86 stock with t-5. I played with the key release button under column when it wouldn't start and the next key turn started up, but then next day tried it again and it didn't help. Lastly, when I turn the key to the on position, I can hear fuel pump priming, and usually gauge buzzer goes off. Dash lights are always on when this happens, but the times it doesn't start I don't hear fuel pump. Any ideas?
Sgt_Syke is offline   Reply With Quote
Old 02-13-2014, 01:45 AM   #2
Red89's Avatar
Not sure if you tried this but I just had the same issue on my '89. Traced and checked everything for weeks. Ignition switch, TFI, solenoid, coil, all grounds and relays. Someone on the forum said check the PIP in the distributor. I changed the dizzy out and fired right up. No problems since.
Red89 is offline   Reply With Quote
Old 02-13-2014, 11:21 AM   #3
Sgt_Syke's Avatar
Going out of town today, will look at it when I get back.
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
my car will die and start right back up again! HELP Josh.0 Pre-2005 V6 Mustang 25 06-07-2012 11:47 AM
Wont Start Balltaatic01 1996-2004 Mustang GT 10 05-07-2012 05:44 AM
04:17 PM
