Cold engine - Mustang Evolution
Old 02-22-2014, 04:35 PM   #1
HeatherKristang's Avatar
Cold engine
My engine was reading cold and not warming up. I changed out the thermostat and still having the same issue. The engine is definitely getting up to temp now but it's still reading cold. All of the other dash stuff is still working fine except for the mileage calculator. When I bought the car the guy said the heater core was out. Does this affect engine temp readings? Or is there something I'm missing? Could only the dash temperature gauge be out? Please help, I'm at a loss here. Not too familiar with mechanical work. Dumb and young female lol...
HeatherKristang is offline   Reply With Quote
Old 02-22-2014, 06:25 PM   #2
Adogg's Avatar
Well what degree thermostat did you get? Does that temp gauge move at all or does it look lifeless? My buddy with a dodge Dakota has a bad heating core in it and his engine temp stays pretty low and his heat doesn't work. Does your heat work?
Don't hate....... appreciate
Old 02-22-2014, 07:59 PM   #3
Sgt_Syke's Avatar
Temp gauge could be out...stock gauges were notorious for breaking, especially since its probably 20-30 years old.
Sgt_Syke is offline   Reply With Quote
Old 02-22-2014, 09:20 PM   #4
92coupe's Avatar
Mine reads just like that. I believe the gauge is somewhat correct because my fans kick on around 200 and they rarely kick on (mid summer in traffic is the only time the gauge gets to the middle and fans kick on). I also believe it isn't the heater core because when the gauge gets to the center it blows hot.
92coupe is offline   Reply With Quote
Old 02-23-2014, 08:57 AM   #5
I got the standard part for the car not sure of it's specs and the old one was in fact stuck open. It was obvious once I got it out of there. The gauge does move but never even close to normal temp. Doesn't seem to be putting off any engine heat through the vents but I haven't driven far yet and it's in the 60's so it's a little hard to judge. But I was surprised it runs much better now in general. She sounds happy.
Old 02-23-2014, 09:02 AM   #6
Cold engine
So strange. I have the heater core but I'm not about to just start tearing the car apart for a little warmth...may consider that next winter I guess. But I just don't get it. I hope it's not a bad thing. I was told the thermostat may be partially responsible for my epic gas burnage so maybe at least that issue is resolved now. We will find out.
Old 02-23-2014, 09:11 AM   #7
olds442111's Avatar
Send a message via AIM to olds442111
Checked the sending unit for the gauge?
White 2014 GT Premium / Blower / Auto Trans / Louisiana
Blue 2016 Sport FX4 Crewcab / Blower coming soon
olds442111 is offline   Reply With Quote
Old 02-23-2014, 09:57 AM   #8
I have to get in there soon anyway I will try to figure that out
Old 02-27-2014, 07:00 PM   #9
89GTstanger's Avatar
My guess is you just need either new sending unit or guage. I would replace the sending unit. I'm leading towards that.
You can't lose if you put God first!
1989 LX, 306 with TF top end kit, Anderson N-21 cam, TKO 600 trans with steel splatter shield,full Maximum Motorsports Mustang maximum Grip box, Detroit locker rear end with 31 spline Moser axles. Staggered wheels with Nitto 555 315/35/17 out back.
89GTstanger is offline   Reply With Quote
Old 03-10-2014, 01:41 AM   #10
slade95gt's Avatar
Worst comes to worst get an aftermarket mechanical temp gauge ..... Very easy to install..... Takes about 15 minutes at the very least that'll tell I if it's the gauge or not
slade95gt is offline   Reply With Quote
Old 03-10-2014, 05:42 PM   #11
Red89's Avatar
I was having gauge reading issues. Wasn't sure if it was the gauges or sending units. I just purchased a pair of Autometer gauges (temperature & oil pressure) and installed them over the weekend. In addition to looking great, my readings are right where they should be. Temperature 190 and oil pressure between 25-50 depending upon idle or power. Might be worth considering.
Red89 is offline   Reply With Quote
Old 03-11-2014, 06:41 PM   #12
Davesorl04gt's Avatar
Good video's on You Tube for for testing sending units. I'd send you a link but I'm computer illiterate.
Davesorl04gt is offline   Reply With Quote
Old 03-12-2014, 04:21 PM   #13
slade95gt's Avatar
Mustangs are notorious for the factory cluster going out.... That's y I went with all aftermarket gauges and it fixed tha problem
Old 03-12-2014, 04:36 PM   #14
Adogg's Avatar
Those are really nice looking man, how hard where they to install I wouldn't mind getting them.
Old 03-12-2014, 04:43 PM   #15
Red89's Avatar
Really easy. Got the entire set up from Jegs. Hardest part was actually trimming the vent diverters to work in the gauge gate. Wiring was simple. Common power to headight on switch for illumination, common ground for illumination to dash support. Then ignition on for gauge power, common ground for gauges to battery negative and leads to both new sending units. Honestly only 2-3 hours. So worth it and the look so cool functioning while I am driving.
The Evolution/Future Build of My Car (Tons of Pics and Vids) DutchManDann 1996-2004 Mustang GT 90 08-01-2017 09:52 AM
Thoughts on cold air intake Sluder4 Pre-2005 V6 Mustang 6 12-14-2012 08:41 AM
Cold Air Intake 03fastblack 1996-2004 Mustang GT 33 02-26-2012 01:27 AM
Unsure of my engine Nate98stang 1996-2004 Mustang GT 11 12-13-2011 08:17 AM
Engine seized! 2012 gt 5.0 8WOOD 2011-2014 Mustang GT 94 12-01-2011 12:39 AM
01:20 PM
