Best Gear for my Power Range - Mustang Evolution
Old 03-05-2014, 09:30 AM   #1
Slow4V's Avatar
Okay as some of you might remember I bought a Foxbody , I'm still in the process of my build. The order of my build is going something like this
- Rear End
- Suspension
- Engine
- Transmission
- Interior
- Exterior
Well so far for my rear end I've bought
31 spline axles ,
03-04 cobra diff
C Clip eliminators
Longer Studs
Next I'm going to order Gears and bearing kit , but I'm trying to get opinion on a good gear.. This is going to be a drag car, 408 stroker , 200 shot
But I still want to play on the highway..
Should I go 410s?
I have them on my 5 speed Mach 1 and love them .. Just don't know if I should go higher
Old 03-05-2014, 09:39 AM   #2
Ish416's Avatar
With that kind of power, a taller gear would likely be better. I would say either a 3.73 or 3.55 would be best.
Old 03-05-2014, 11:32 AM   #3
Slow4V's Avatar
Even for strip ?
Old 03-06-2014, 09:35 PM   #4
Ish416's Avatar
If you want to play on the highway at all .. 4.10's aren't good.
Old 03-06-2014, 09:51 PM   #5
Slow4V's Avatar
Really? I have tons of top end with my 410s , I actually walk 3:55 / 3:73 mustangs around my power level from 3rd gear rolls
Old 03-06-2014, 10:56 PM   #6
You also redline A LOT higher in the Mach than you will in the fox.
Old 03-07-2014, 09:21 AM   #7
Slow4V's Avatar
The 408 setup I'm going have to going to redline around 7-8,000 ..
Old 03-07-2014, 01:40 PM   #8
Ish416's Avatar
You will have to have a great intake, some awesome heads and a wicked cam to make any sort of power at that rpm with that engine.
Old 03-07-2014, 02:21 PM   #9
Site Sponsor
Sponsor
AMWill's Avatar
We need to know what tire height and transmission you're using before picking a gear size. Otherwise there's nothing to base the recommendation from. Also, how much power are you planning to make all motor with the 408w? How light will your race weight be? If your transmission is a manual, then you're going to want the right gear ratio to finish in 4th at the quarter mile on the 200hit.
I recommend solid roller lifters and a 4barrel throttle body if you want to spin the engine to 8k rpm. Of course the right cylinder heads and camshaft are important, but they're not the only factor to supporting 8k rpm.
Sounds like a killer build though. I wish you the best with it!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 03-07-2014, 05:48 PM   #10
You don't need to rev that high with a 408, you can stay in the high 6s and be fine. Even a mild 408 properly done will be doing a ridiculous amount of torque at a pretty low RPM so I would not do 410s. Heck I'd do 3.55s or even 3.31s honestly.
Old 03-07-2014, 09:13 PM   #11
2300turboford's Avatar
+1 my dads 408 spun on 8.5 inch slicks with 3.25 gears I would probably go with a 3.55s
Sent from my DROID RAZR using Mustang Evolution mobile app
4.10 Gear Speed/RPM Video svtlx 1996-2004 Mustang GT 63 03-02-2014 10:16 AM
Gutting cats BadAssStang07 2005-2010 Mustang GT 8 12-07-2013 09:24 AM
Dyno numbers are here!! Benzo 2011-2014 Mustang GT 32 11-07-2011 04:55 PM
New gear install prices XXSTEVEO66 1979-1995 Mustang GT 10 09-02-2011 11:59 AM
Ditching power steering? Stang.racr 1979-1995 Mustang GT 4 08-24-2011 02:36 PM
10:49 AM
