Blown head gasket shop repair cost? - Mustang Evolution
Old 03-05-2014, 01:15 PM   #1
The420fox's Avatar
So I have white smoke coming out of my exhaust and it shakes a bit when turned on so I figured head gasket. So my question is how expensive is it for a head gasket repair?
The420fox is offline   Reply With Quote
Old 03-06-2014, 01:42 AM   #2
Red89's Avatar
I think every location may be different. Have you thought about trying it yourself? With all of the great advise I get on all of the forums I have been able to tackle every issue myself, most of which I thought were way above my skill level and had great results. Amazing how much money I was able to put towards upgrades when I didn't spend it at at a shop.
Red89 is offline   Reply With Quote
Old 03-06-2014, 01:45 AM   #3
The420fox's Avatar
This is the first time takin it to a shop I do all my work I'm kinda sick of it I rather pay depending on cost bit I might if my quote is to much
Old 03-06-2014, 01:52 AM   #4
DaBluedude's Avatar
Honestly, if it's bad and you need the block trued, it's expensive. If it's minor, and you think you can get away with just replacing the gasket... You could get away with about 300$ in parts. Head gaskets are serious work. If you are confident, and are good following directions, it is doable, but there are a lot of things you could screw up. At the end of the day, it comes down to your ability level, if you're having a shop do it. Get a couple grand set aside.
2003 Mach 1
Old 03-12-2014, 04:30 PM   #5
slade95gt's Avatar
Where are u located I'm always willing to help out a fellow mustang driver I have a shop in houston and I'll cut u a solid deal
slade95gt is offline   Reply With Quote
Old 03-13-2014, 01:48 PM   #6
We're is your shop slade
Sent from my SCH-R830C using Mustang Evolution mobile app
---------- Post added at 07:48 PM ---------- Previous post was at 07:47 PM ----------
Im here in Houston and need a good mechanic
pcarouthers is offline   Reply With Quote
Old 03-13-2014, 02:36 PM   #7
HG is easy on a 5.0. Buy a chiltons and go step by step and you are good to go. Should take a day if you have the tools. Make sure you buy ARP head bolts or studs though.
First off though, make sure its the HG, could be the valve stem seals leaking. Leakdown test will pinpoint which cylinder(s) have issues though.
Old 03-13-2014, 05:09 PM   #8
The420fox's Avatar
Thanks
Old 03-13-2014, 09:21 PM   #9
slade95gt's Avatar
It's sw of houston actually in needville I'm like 35 mins to an hr from houston depending which side of houston your on my shop is 36 auto and transmission off hwy 36 which is right off of 59
Old 03-13-2014, 09:24 PM   #10
slade95gt's Avatar
We specialize in ford.... Especially mustangs being that pretty much everyone here has one lol the actual owner of the shop has three ranging from a 60s model fastback to two 80's model fox bodies .... And I have an sn-95 I run the place so come holla at me man
HELP - repair cost? Jmanlev 1979-1995 Mustang GT 27 12-13-2012 05:27 PM
Head Gasket Question!?!?!? FORDGT14 1996-2004 Mustang GT 33 12-31-2011 12:19 PM
Repair shop recommendation around San Jose faddy Regional Mustang Discussion 0 09-07-2011 12:58 AM
Head gasket question ? WhiteCobra94 1979-1995 Mustang GT 17 08-30-2011 09:33 AM
Spark plug blown out of head. 1bad2v 1996-2004 Mustang GT 17 07-03-2011 08:29 PM
11:34 PM
