help with explorer intake - Mustang Evolution
Old 03-06-2014, 01:49 PM   #1
ricky1379's Avatar
i'm about to change the intake manifold on my mustang 88 to an explorer manifold but i don't see no gaskets or nothing..just the intake.
what am i going to need for a succesful change to an explorer intake?
ricky1379 is offline   Reply With Quote
Old 03-06-2014, 02:14 PM   #2
ALMOST STOCK's Avatar
Here yeah go...... Ford Mustang: Mustang Tech: Induction: Explorer Intake Install
ALMOST STOCK is offline   Reply With Quote
Old 03-06-2014, 02:24 PM   #3
You might PM Red89 while things are still fresh on his mind he just got finished doing his explorer install a week or so ago.
Mustang Evolution - View Profile: Red89
Old 03-06-2014, 06:11 PM   #4
Red89's Avatar
I just did this last weekend. Any questions ask away. I took my time, prepped and bought everything upfront and it went like butter. Was very enjoyable to do myself. Shop wanted $380 plus parts and unknowns. I was looking at $500. For that I bought new Accell injectors, new gasket kit, new vacuum hoses, powder coated my intake and valve covers (myself), purchased Autometer temperature and oil pressure gauges along with the vent gauge cage. I also did an oil change and cleaned everything up. FOR LESS!!!!!!!
Red89 is offline   Reply With Quote
Old 03-06-2014, 06:36 PM   #5
ricky1379's Avatar
what are those 2 hoses on each side of the throttle body?
mine don't have em
Old 03-06-2014, 06:49 PM   #6
Red89's Avatar
EGR coolant tubes. Coolant runs through the throttlebody
Old 03-06-2014, 06:51 PM   #7
ricky1379's Avatar
so do i need to install them once i get the 65 mm throttle body that goes in to the explorer intake or is it 70mm?
and where do the hoses connect?
i'm asking all this because i'm gonna do it myself....i don't trust mechanics here to do a perfect job on this
Old 03-06-2014, 07:20 PM   #8
Red89's Avatar
My car, an '89, came with them on the original throttle body. When I put the BBK 70mm on, there were ports for it. The front one comes out of the heater tube towards the front of the manifold. The rear returns to a barb fitting on the rear passenger side of the intake behind the #4 cylinder. I had to drill and tap that one. In the picture it is directly behind/ under the fuel pressure regulator. If you look at the opposite side you can see another untapped boss. You can drill and tap that one if you want to use a temperature gauge but also have the factory one still work.
Old 03-06-2014, 07:49 PM   #9
5.oh's Avatar
The stock explorer throttle body has to have some modifications done to it also. You have to keep the throttle bracket and somehow make that work also. That's the only way the explorer throttle body will work with it. It's a little different then the regular 5.0 intake
Sent from my SM-N900T using Mustang Evolution mobile app
5.oh is offline   Reply With Quote
Old 03-07-2014, 02:34 AM   #10
Red89's Avatar
It is definitely worth you purchasing a new 70mm throttle body. This way it is more plug and play.
Old 03-22-2014, 10:11 PM   #11
5.oh's Avatar
Exactly. And red89. You mentioned you got a new vent gage cage. What is that?
---------- Post added at 10:11 PM ---------- Previous post was at 10:11 PM ----------
Btw red. That engine looks clean. Reds my color and I'd love to have mine looking like that one day
Old 03-23-2014, 04:59 AM   #12
Red89's Avatar
I wanted to put a set of Autometer gauges in the car, one for oil pressure and the second for water temperature. I didn't like the look of the pillar pod on a convertible so I bought a gauge cage. It is a gauge holder that replaces the center vent above the a/c controls, holds two gauges and retains the vent registers. You do have to modify the size but it was really worth it.
Auto Meter 50101 Auto Meter Gauge Cages - Free Shipping on All Orders @ JEGS
Old 03-23-2014, 09:21 AM   #13
ricky1379's Avatar
cool lights on your car..
where did you get em?
Old 03-23-2014, 09:23 AM   #14
Red89's Avatar
American Muscle. Only $39.99. Went in easy and look sweet daytime or night.
Mustang White Face Reverse Glow Gauge Insert - 85mph (87-89 All) - Free Shipping
Old 03-23-2014, 10:05 AM   #15
ricky1379's Avatar
thank you
Old 03-23-2014, 11:31 AM   #16
5.oh's Avatar
Sweet! That looks clean. Thanks man!!
Check engine soon light came on? KamzGT Pre-2005 V6 Mustang 27 09-14-2013 04:33 PM
mustang gt intake issue Jar72 1979-1995 Mustang GT 6 10-11-2012 07:51 AM
Upper intake Removal/VAP Auto installation ForsakenProto Pre-2005 V6 Mustang 22 07-06-2012 06:49 PM
Intake from 97 explorer? Army_Stang 1979-1995 Mustang GT 10 12-03-2011 12:54 PM
Explorer Intake? crkmonzo 1979-1995 Mustang GT 7 09-19-2011 11:41 AM
10:36 PM
