Drum to disk swap - Mustang Evolution
Old 03-07-2014, 08:03 AM   #1
Foxresto's Avatar
Drum to disk swap
Hey guys I'm looking into doing the 5 lug swap on my 82 fox. Iv heard I need to update my rotors with bigger ones and different calipers to go with it in the front. Iv got drum brakes in the back but I would like to have disk brakes all the way around. I'm going to be getting the rotors and calipers and anything else I need at the local scrap yard because they have cheap deals.
My question is what in all would I need to swap my stock rotors (8" or 9") with bigger ones.
Do I need different calipers or would my stock ones work? The car used to be a 4 banger.
And what do I need to do to swap my drum brakes for disks
Foxresto is offline   Reply With Quote
Old 03-07-2014, 09:06 AM   #2
TruChris's Avatar
I am going to be doing this also on my fox., But i am only doing the rear 5 lug conversion with disk brakes from an SN95. Why do you want to switch front rotors? Also if you plan to do the rear disk conversion you're going to need a new master cylinder.
TruChris is offline   Reply With Quote
Old 03-07-2014, 09:29 AM   #3
Foxresto's Avatar
For one there 4 lug rotors and I have 5 lug rims and tires ready to throw on. The tires are 17x9s and heard the rotors need to be bigger because the stock size have a hard time stopping them. Not sure how true this is but that's just what iv heard.
Old 03-07-2014, 10:17 AM   #4
TruChris's Avatar
Oh haha well I can't help very much with the front conversion cause I have done no research for it. It doesn't seem as hard as the rear tho because you don't need to replace the whole axle right? Haha
Sent from my SAMSUNG-SM-N900A using Mustang Evolution mobile app
Old 03-07-2014, 11:00 AM   #5
ALMOST STOCK's Avatar
This will definitely help you then for the front and the rear.
87-93* Ford Fox Body Mustang Brake Upgrades
ALMOST STOCK is offline   Reply With Quote
Old 03-07-2014, 08:46 PM   #6
Foxresto's Avatar
Originally Posted by ALMOST STOCK View Post
This will definitely help you then for the front and the rear. 87-93 Ford Fox Body Mustang Brake Upgrades
Thanks I will look into it! The old drums just don't cut it anymore lol
Old 03-09-2014, 08:21 PM   #7
slade95gt's Avatar
Be careful going to big with rotors though..... This is assuming u we're using stock rims...... If u go with 9 inch id look into a 17 inch rim like a svt rim
slade95gt is offline   Reply With Quote
Old 03-10-2014, 01:41 PM   #8
Foxresto's Avatar
Iv already got the rims and tires ready. They came off my 98 awhile back before I sold it. There the billet 17" rims with Nitto 555s. 245 in front and 275 in back. Do you know what size the sn95 stock rotors are?
Old 03-10-2014, 01:54 PM   #9
Foxresto's Avatar
Well I took the first step into the 5 lug swap. I was just going to loosen everything until I got the new parts ready to throw on but jumped ahead of myself.
I took off the old calipers, rotors, and spindles.
Going to pick up a ball joint press probably tomorrow to finish the removal process and put some new ball joints in. Better to do it now that everything is off and not later lol
Old 03-10-2014, 04:28 PM   #10
94-98 Front GT/V6 rotors are 10.84" with 66mm caliper.
94+ Rear GT/V6 rotors are solid 10.5" with 38mm caliper.
94-98 Cobra Front 13" rotor with PBR 38x38mm caliper.
94+ Cobra Rear 11.65" vented rotor with the same 38mm caliper.
99+ Cobra Fronts 13" rotor with PBR 40x40mm caliper.
When you replace the ball joints you'll either need to get the SN 95 ball joints or a 0.330" tall spacer, 5/8" inside diameter , 1.5" outside diameter (or a stack of washers totaling 0.330").
Old 03-10-2014, 08:17 PM   #11
Foxresto's Avatar
94-98 Front GT/V6 rotors are 10.84" with 66mm caliper. 94+ Rear GT/V6 rotors are solid 10.5" with 38mm caliper. 94-98 Cobra Front 13" rotor with PBR 38x38mm caliper. 94+ Cobra Rear 11.65" vented rotor with the same 38mm caliper. 99+ Cobra Fronts 13" rotor with PBR 40x40mm caliper. When you replace the ball joints you'll either need to get the SN 95 ball joints or a 0.330" tall spacer, 5/8" inside diameter , 1.5" outside diameter (or a stack of washers totaling 0.330").
Are the sn95 ball joints any better than the fox ball joints? I know the fox joints are taller but does it matter at all?
Old 03-10-2014, 09:02 PM   #12
I don't know if there are any better but if you're changing ball joints anyway why not get what works without adding either spacer or a stack or washers is my theory.
Old 03-10-2014, 09:33 PM   #13
Foxresto's Avatar
That is true lol i should be getting everything I need in the next week or so
2011 3.7L V6 6R80 to MT-82 swap completed 3.7Cyclone 2011-2014 V6 Mustang 17 12-24-2014 12:00 AM
5.4 swap CoolHorsey General Mustang Discussion 18 07-19-2014 01:35 AM
Mark viii swap? matthewhst11 Pre-2005 V6 Mustang 24 06-15-2013 09:12 AM
Motor swap Wmcgrattan General Car Discussion 35 12-05-2012 04:36 AM
Engine swap question!! Tominkc 1996-2004 Mustang GT 1 02-09-2012 12:15 AM
10:12 AM
