SPOUT connector / Timing - Mustang Evolution
Old 03-11-2014, 08:52 AM   #1
88ShiftyFifty's Avatar
I was adjusting my timing last weekend. When I got done, it slipped my mind and I forgot to plug the spout connector back in. When I realized it, I went to look for it and couldn't find it.
1) Will I damage anything by driving the car without the spout connector in there? I get my new one on Thursday. Ordered it online.
2) I was told that advancing the timing will get more performance out of the car. What do you guys have your timing set at?
Thanks in advance for the replies.
88ShiftyFifty is offline   Reply With Quote
Old 03-11-2014, 09:31 AM   #2
mystang50's Avatar
@1 I honestly don't know...
@2 yes advancing the timing will squeeze some power out, but you'll have to run higher octane gas to prevent detonation.
mine was advance a couple degrees to high and was detonating, had to pull some, but now its set for nitrous.
Old 03-11-2014, 11:01 AM   #3
I only pump 91 octane gas at chevron.
How advanced did you have yours that it was detonating?
Old 03-18-2014, 06:50 AM   #4
Durnstang's Avatar
Without the spout in your EEC can not control the timing as the rpm raise. you're base timing is set and that's all you get
---------- Post added at 07:50 AM ---------- Previous post was at 07:49 AM ----------
Also nothing will be damaged,
Durnstang is offline   Reply With Quote
Old 03-18-2014, 07:59 AM   #5
mystang50's Avatar
That is what i hought, but didn't want to give wrong info, but this sounds right!!
Spout connector 86gt 1979-1995 Mustang GT 7 10-01-2011 03:50 PM
04:33 AM
