91 gt harness swap?????? - Mustang Evolution
Old 03-14-2014, 05:26 PM   #1
busaboy's Avatar
grrrrrrr ok so i had a problem with my lights dim and both markers blinking on drivers side with left turn signal. looked through wires couldnt find anything pulled dash off and bam found melted wires!!!!!! well i went and got a harness for 180 bucks at the salvage yard out of a 91 which is my year but when i got back home i started to look it over and noticed it is the wrong one!!!
I know if its an 87-91, you will have 1 large relay mounted under the MAF and
If its a 92-93, you will have 2 large relay's mounted under the MAF, mine has two but its a 91 so that means someone switched that harness because it should only have 1 and it only has one brown pin connector and if its an 87-90, you will have 2 large plugs next to the code plugs by the brake booster. One brown, one black.
If its an 91-93, You will have 1 large plug next to the code plugs by the brake booster. Brown only
I am so confused right now something isnt adding up here please help me
also, the one i bought today has 2 pin connectors one grey and one black out of a 91 what the heck nothing is right
busaboy is offline   Reply With Quote
Old 03-15-2014, 01:27 PM   #2
busaboy's Avatar
Can someone just tell me if I have 1 plug by brake booster (brown) and 2 relays under maf...what year do I need
Old 03-15-2014, 02:11 PM   #3
ALMOST STOCK's Avatar
My guess is what you have is 92.5-93
The 91-92.5 harness would be described as follows:
"Fuel pump relay is under the driver seat, EEC relay is right next to the computer and the 1 relay by the MAF is the WOT ac relay and there is one brownish/reddish connector that connects to the under dash harness in the engine compartment. If your harness is like this, it’s set up for a 91".
5.0L Mustang Wiring Harness Details | Mustang Tech Articles | CJ Pony Parts
ALMOST STOCK is offline   Reply With Quote
Old 03-15-2014, 08:14 PM   #4
busaboy's Avatar
But I have no relays under my seat!! So what is the other relay by my maf, that's in the engine compartment right under my cai right? There are two little boxes (relays) then by the brake booster there's a brown plug. My big concern is finding the right year main harness for what is there now and finding out what fried my wires to begin with
Old 03-15-2014, 08:28 PM   #5
TWO relays by the MAF (A/C wide open throttle and the fuel pump relay)
Old 03-15-2014, 08:37 PM   #6
busaboy's Avatar
Ok just pulled my computer...it says 93 mustang coupe blue meaning it's from a salvage yard mines a 91 hopefully when they changed the computer they changed the wiring harness with same car I guess
Old 03-15-2014, 08:38 PM   #7
Brown Connector.
Old 03-16-2014, 02:32 AM   #8
slade95gt's Avatar
Post pics of what your looking at when possible
slade95gt is offline   Reply With Quote
Old 03-16-2014, 08:46 AM   #9
busaboy's Avatar
By brake booster
Old 03-16-2014, 08:47 AM   #10
busaboy's Avatar
By maf
Old 03-16-2014, 08:48 AM   #11
busaboy's Avatar
Computer
Old 03-20-2014, 10:20 AM   #12
slade95gt's Avatar
So what exactly is the car doing
How to install a 2013 Mustang Track Apps Instrument Cluster in a 2013 Base model GT Deerslayer 2011-2014 Mustang GT 967 05-24-2018 09:02 AM
2011 3.7L V6 6R80 to MT-82 swap completed 3.7Cyclone 2011-2014 V6 Mustang 17 12-24-2014 12:00 AM
97 GT 32V Swap 95v686gt 1996-2004 Mustang GT 537 09-27-2013 02:32 PM
what does it take to outrun a GT? austinknoll Pre-2005 V6 Mustang 72 01-14-2012 01:19 PM
5.0 HO swap gc19662007 1979-1995 Mustang GT 16 11-25-2011 08:33 PM
10:34 AM
