Need a new 302 engine - Mustang Evolution
Old 03-16-2014, 01:37 PM   #1
antnvlz1294's Avatar
Question Need a new 302 engine
My buddy has the same model fox as I do. Where can I get a new 302 pushrod 5.0 engine? He needs a stock engine with little to no miles preferably new, and wants to get one to replace his 302 stock fuel injected engine thats slowly going out. He doesnt want to spend more than $1600 at most and needs it to be for his manual t5 transmission. He called ford and they want $4500 for a replacement... so he doesnt want to do that. He would use his stock intake manifold and all parts off of his current engine. Let me know so I can spread the word!
Thanks guys.
antnvlz1294 is offline   Reply With Quote
Old 03-17-2014, 06:29 AM   #2
Dion11197's Avatar
I know on the top mustang sites they usually have a budget block with rotating assembly for $1,000.00. You can also check your local Craig's List ads. I've seen complete engines from intake to oil pan with 30k miles listed for $1200.
Dion11197 is offline   Reply With Quote
Old 03-17-2014, 07:04 AM   #3
But how do I really know that there is the miles they say on the engine?
Old 03-17-2014, 07:13 AM   #4
Dion11197's Avatar
That's the thing, you won't unless they still have it in the car and you can verify mileage, if they haven't rolled back the odometer.
If that's a concern, the only safe bets are rebuilding what's already there, or buying a new block and rotating assembly.
Old 03-17-2014, 07:19 AM   #5
Dang that sucks.. i wonder if anyone on here has one..
Old 03-17-2014, 07:21 AM   #6
Dion11197's Avatar
They may, or try the coral.
---------- Post added at 06:21 AM ---------- Previous post was at 06:21 AM ----------
Corral that is.
Old 03-17-2014, 07:30 AM   #7
Corral that is.
Okay will do. Thanks for everything
Old 03-17-2014, 07:58 AM   #8
Dion11197's Avatar
You bet! If he's looking for a bit of a performance boost, he can look for a 96-2001 explorer 5.0. Comes with a GT 40 cast intake and either gt40 or gt40p heads. I just found one at a local recycler for $450. Then of course he'd want to rebuild it. That's an option also.
Old 03-17-2014, 08:01 AM   #9
Well I know he only wants to get another engine because he is hearing a knocking when the engine is running.. He thinks it's a rocker and he doesn't know what or how to do with the issue. Him and I both are new to mustangs.
Old 03-17-2014, 08:07 AM   #10
Dion11197's Avatar
I would recommend further investigation. If you have access to a mechanic who has a mechanics stethoscope, they can listen to the top and bottom of the engine and determine if it's a top end issue like lifter or rocker arm vs. Bottom end which is a much more serious issue. If it's just a rocker arm or lifter, it much easier to fix and cheaper!
Old 03-17-2014, 08:12 AM   #11
I would although the only one by me who has a mechanics stethoscope wants to charge him $400 just to look at it... and his engine has only 102k miles too..
Old 03-17-2014, 08:17 AM   #12
Dion11197's Avatar
Yeah, that's half the price of a budget bottom end.... That dude's insane!!
Louder Sound Idea!! MustacheMustang 2011-2014 V6 Mustang 196 05-19-2013 02:21 PM
selling a 1989 4 cylinder mustang with a 5.0 engine and transmission both working 1987mustanglx50 2.3 Mustang 0 01-25-2012 01:30 PM
16 Valve GT To 32 Valve Cobra Engine Swap 504 Stang Rida 1996-2004 Mustang GT 5 08-23-2011 05:29 AM
Engine died at low speed. Could not start engine in hot weather Ucla1998 Pre-2005 V6 Mustang 5 08-09-2011 02:15 AM
Boss 302 vs GT 5.0 poloka 2011-2014 Mustang GT 188 06-20-2011 04:08 PM
11:41 AM
