Got a coolant leak - Mustang Evolution
Old 03-17-2014, 11:21 AM   #1
Adogg's Avatar
Got a coolant leak
Hey guys, as you can see I got some bad news. The other day was getting on the high way and I was getting her up to high way speeds and then white smoke everywhere. Luckily the temp gauge was staying normal (stock gauge). So I drove maybe a mile and pulled in to a parking lot. There was a lot of coolant coming out on to the ground like middle engine like where the tranny meets the motor. There is no coolant leaking from the radiator area, and when you start the car no white smoke out the tail pipes. I have tried locating something easy like a disconnected hose but I havnt had any luck. I have not had anytime to do any major searching, there was a recent death in the family. So if you guys have any idea on where to start looking or any sort of help I would appreciate it.
Thank you
Adogg
Don't hate....... appreciate
Old 03-17-2014, 03:15 PM   #2
slade95gt's Avatar
Standard or auto tranamission
slade95gt is offline   Reply With Quote
Old 03-17-2014, 03:22 PM   #3
slade95gt's Avatar
If it's auto there are coolant lines that run from radiator to tranny and that could be where your problem is as they are pressurized...... And pray it's not a cracked block
Old 03-17-2014, 03:32 PM   #4
Adogg's Avatar
Nope it's a standard, let's hope and pray it's not that . When I have the free time and better weather I will crawl under there and check it out. Thank you for the help
Old 03-17-2014, 03:39 PM   #5
Tyoung68's Avatar
I have a leak in the same spot mine was a freeze plug not sure if you car has them in the same spot and the lines that go from the rad to the tranny dont have coolant in them its atf
Old 03-17-2014, 03:41 PM   #6
Adogg's Avatar
What motor do you have? And mine is a 5 speed so it doesn't have those lines anyways.
Old 03-17-2014, 03:43 PM   #7
Tyoung68's Avatar
Well i have a 68.... With a l6 haha but almost all engines iv seem has a freeze plug in between the engine and tranny
Old 03-17-2014, 03:46 PM   #8
Adogg's Avatar
Ooooo alright I will have to look In to that too. I don't see many wet spots on the motor just a Little on the firewall and tranny and undercarriage.
Old 03-17-2014, 03:52 PM   #9
Tyoung68's Avatar
Well for your sake i hope its not that! Its a real pita to fix it
Old 03-17-2014, 04:01 PM   #10
Adogg's Avatar
Oooo damn really? Well it's better then a cracked block. Where is it usually located?
Old 03-17-2014, 04:04 PM   #11
Tyoung68's Avatar
Well iv always seen them under the bellhousing so you would have to drop the tranny to get to it
Old 03-17-2014, 04:05 PM   #12
Adogg's Avatar
Damn well thank you for the info. Is there a way to test if it Is bad before dropping the tranny?
Old 03-17-2014, 04:16 PM   #13
Adogg's Avatar
Old 03-17-2014, 06:00 PM   #14
Tyoung68's Avatar
Old 03-22-2014, 12:09 PM   #15
5.oh's Avatar
You can get a pressurizer. Hooks to the top of the radiator, then it has like a tire pump on it. You pump it and watch where it leaks. Of course you wanna get about 20-25 psi outta it but if you have a major leak like a freeze plug your going to want someone pumping it for you constantly while you get under the car and watch where it's leaking.
Sent from my SM-N900T using Mustang Evolution mobile app
---------- Post added at 12:07 PM ---------- Previous post was at 12:06 PM ----------
Fill the radiator with just plain water too.
---------- Post added at 12:08 PM ---------- Previous post was at 12:07 PM ----------
http://m.harborfreight.com/radiator-...d#.Uy3RkVAo7qA
---------- Post added at 12:09 PM ---------- Previous post was at 12:08 PM ----------
That is a harbor freight one.
5.oh is offline   Reply With Quote
Old 03-22-2014, 12:12 PM   #16
Adogg's Avatar
Thanks guys ended up being the heat hoses where pretty messed up.
Old 03-22-2014, 02:00 PM   #17
5.oh's Avatar
Yep no probelem!!
Lost coolant no leak anywhere skorch85 General Mustang Discussion 11 02-15-2014 10:37 PM
1997 Mustang GT Coolant Leak Aftermath XSlashDashX 1996-2004 Mustang GT 10 01-14-2014 02:26 PM
Coolant leak Napoleon 1979-1995 Mustang GT 12 01-15-2012 01:47 PM
'05 V6 coolant leak? afree05 2005-2010 V6 Mustang 18 09-24-2011 03:42 AM
horrible coolant leak...ideas? shustwit Pre-2005 V6 Mustang 3 06-30-2011 12:48 PM
01:55 AM
