More codes... help? - Mustang Evolution
Old 03-23-2014, 05:10 PM   #1
antnvlz1294's Avatar
Unhappy More codes... help?
I have an 88 mustang 5.0 lx. I previously had a code which was stating that my right side O2 sensor was running lean. I checked and the sensor was wiggling around. Now today (a few weeks later) I went to autozone and bought two of the same Bosch Oxygen sensors (both were same kind and model number) for 39.99 to install on my mustang. I put both of them in with the battery cables off, and decided to run my coder to make sure that the previous code went away. My car was warmed up when I did the koer test and I code two codes.
Code 44: problems in thermactor air control system
and
Code 94: thermactor air system - problem on the right bank (passenger Side). or, Transaxle problem - shift solenoid 1 (ss1) circuit failure.
What exactly is my issue here, what do I have to replace?
antnvlz1294 is offline   Reply With Quote
Old 03-23-2014, 06:55 PM   #2
ALMOST STOCK's Avatar
Code 44 RH side air not functioning.
Code 94 LH side air not functioning.
If you have eliminated your TAB and TAD solenoids you will get those codes.
The computer uses the change in the O2 sensor readings to detect operation of the Thermactor control valves. When the dump valve opens, it reduces the O2 readings in the exhaust system. Then it closes the dump valve and the O2 readings increase. By toggling the dump valve (TAB), the computer tests for the 44/94 codes.
Failure mode is usually due to a clogged air crossover tube, where one or both sides of the tube clog with carbon. The air crossover tube mounts on the back of the cylinder heads and supplies air to each of the Thermactor air passages cast into the cylinder heads. When the heads do not get the proper air delivery, they set codes 44 & 94, depending on which passage is clogged. It is possible to get both 44 & 94, which would suggest that the air pump or control valves are not working correctly, or the crossover tube is full of carbon or missing.
ALMOST STOCK is offline   Reply With Quote
Old 03-23-2014, 07:07 PM   #3
So I don't even know what tab or tad solenoids are? As for fixing this issue what do I clean or replace? You said something about tubing getting clogged? What exactly are you referring to? I don't understand what I have to do?
Old 03-23-2014, 07:46 PM   #4
Tab and Tad solenoids are on the back side of your passenger side tower strut
The cross over tube is attached to the back of the heads and a good possibility that it could be clogged with carbon.
What I did to clean my cross over tube was to run a semi- stiff wire through one end of the tub and out other. If you see a lot of carbon come out of the tube you could use something like carburetor cleaner poured in the tube and let it sit overnight.
More than likely the cross over tube is stopping you from being able to mount your ground cable to the engine block because it's in the way.
You'll need to remover 2 bolts to and disconnect the to remove the cross over tube.
Old 03-23-2014, 07:55 PM   #5
So Disconnect the tube run a thick wire through it and spray/soak the inside with carb cleaner, leave for a night and then put it on?
Old 03-23-2014, 08:06 PM   #6
That's it........You want to clean the tube so that there is no carbon blockage is what you're trying accomplish.
Old 03-23-2014, 08:11 PM   #7
Alright I'll post what happens in a few days.
Help please!!! Eng codes!! Dgerow12 Pre-2005 V6 Mustang 7 09-13-2011 04:07 PM
My gt is throwin codes help Jamesgt08 1996-2004 Mustang GT 4 03-25-2011 11:03 PM
2 Codes Need Help tigerfan2771 Pre-2005 V6 Mustang 12 04-05-2010 09:42 PM
Need Help: Codes P0135 and P0155 96Mustang0250 Pre-2005 V6 Mustang 7 01-27-2010 04:11 PM
help reading gear codes! Sublime782 Pre-2005 V6 Mustang 9 05-26-2005 10:29 PM
05:32 AM
