88 GT gas gauge and speedo/odometer not working. - Mustang Evolution
Old 03-23-2014, 11:08 PM   #1
UDLOOZ's Avatar
I recently purchased this car and needs these issues resolved....
I recently dropped the gas tank and installed a new fuel sending unit but, that didn't fix it. Needle didn't even change location. Stuck on 3/4 of a tank. What should I do next?
Also the speedo/odometer aren't working where do I start? Easiest to hardest
UDLOOZ is offline   Reply With Quote
Old 03-24-2014, 07:48 PM   #2
slade95gt's Avatar
Get u some aftermarket gauges and test them out before install if your wiring is right it could very well be bad gauges this is assuming u have checked fuses first
slade95gt is offline   Reply With Quote
Old 03-24-2014, 08:25 PM   #3
There is a chip on the circuit board behind the cluster that needs replacing. I can't remember exactly what its called. A guy I know had this same problem with his 88lx 5.0. It's a common issue with the 87-88s. They aren't the easiest to find, but a 89gt/5.0lx cluster would be a good upgrade. The later 89s have the 140speedo for the tilt wheel cluster. Sounds like your speedometer cable broke. It's an easy cheap fix.
Bigshow14 is offline   Reply With Quote
Old 03-24-2014, 09:17 PM   #4
UDLOOZ's Avatar
I took apart the instrument panel with aftermarket (white gauges) and the whole circuit board was all torn especially where the wiring harness connects to the rear of the cluster on the gas gauge side...so I am in search of a new cluster I prefer black gauges. Anybody have a 140mph cluster they are looking to sell?
Yes the speedo cable literally had a 90 degree bend in it and was partially burnt/shredded. Easy enough to take out and ordered the whole new setup.
Old 03-24-2014, 09:27 PM   #5
Do you have the mass air set up on your car
Old 03-24-2014, 09:30 PM   #6
UDLOOZ's Avatar
Yes I do, BBK 75mm. Why you ask?
Old 03-24-2014, 09:36 PM   #7
UDLOOZ's Avatar
If you check out my garage I have everything that is on the car listed there.
Old 03-24-2014, 09:37 PM   #8
Just curious, while you are looking for an 89 cluster, the 89 mass air set up is a nice cheap upgrade for your car.
Old 03-24-2014, 09:41 PM   #9
Just checked it out, you have a clean car nice set up. I had an 88gt vert white 5spd
Old 03-24-2014, 09:44 PM   #10
UDLOOZ's Avatar
The only thing I am thinking of doing is looking for new heads, upper and lower control arms and sub-frame connectors. Other than that the car is sitting pretty good as it is.
Old 03-24-2014, 09:53 PM   #11
UDLOOZ's Avatar
Thanks. I literally stole this car for $4500. Right place right time. Just wish it was an LX but it is still a nice Florida car with zero rust anywhere.
Old 03-25-2014, 06:57 AM   #12
UA10GT's Avatar
I like the lx much better as well but sounds like you got a great deal on it
UA10GT is offline   Reply With Quote
Odometer and Trip not working! Please help! prittiecute 1996-2004 Mustang GT 11 02-21-2013 06:18 AM
speedometer and gas gauge not working?? rob913 1979-1995 Mustang GT 0 07-03-2010 08:00 AM
odometer and Trip not working Tim Knox 1996-2004 Mustang GT 2 07-19-2008 12:12 AM
odometer not working 98mustang2007 1996-2004 Mustang GT 4 03-20-2008 10:25 AM
Speedo works, Odometer does not.. floridamba Pre-2005 V6 Mustang 9 04-24-2007 03:02 AM
08:21 AM
