manual t5 oil change - Mustang Evolution
Old 03-23-2014, 11:11 PM   #1
92fox's Avatar
Whats the easiest way to change the trans fluid in t5, i heard of removing the shifter and filling it that way but idk i never tried it. Let me know what you guys do with your t5's, also what fluid do you like to use? thanks.
92fox is offline   Reply With Quote
Old 03-24-2014, 09:24 AM   #2
There are two plugs on the passenger side, make sure you can break the top loose first before you drain out the bottom hole. I didn't want to break the seal/gasket on my shifter, so to refill I just pulled the shifter bezel off and ran a plastic tube from inside the car down into the top hole on the tranny and filled it that way... I thought it was fairly easy.
Adam302gt is offline   Reply With Quote
Old 03-24-2014, 12:59 PM   #3
mustangmania91's Avatar
+1 Adam302gt
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
mustangmania91 is offline   Reply With Quote
Old 03-24-2014, 02:08 PM   #4
92fox's Avatar
What brand oil do you recommend ? I'm not sure if I should use synthetic or regular
Old 03-24-2014, 03:00 PM   #5
Regardless of what kind or type, I used synthetic simply because its a 91 GT. Its a 22-23 yr old car. Go with synthetic
Old 03-27-2014, 06:57 AM   #6
Pennzoil Synchromesh or DexMerc III. Pull bottom plug, drain, re-install plug and DO NOT GORILLA OVERTIGHTEN IT OR YOU WILL CRACK THE CASE. Then fill to spec through the shifter, its the easiest way to put fluid in these things. Whenever I hear of someone buying one of those bottle pumps and filling through the fill hole I laugh. I believe the correct spec for a T-5 is 3.25 qts but I'm not totally 100% on that anymore as I have not had one for a good 10 years now so make sure you look it up.
Old 03-27-2014, 08:51 AM   #7
Ive done it both ways. Easier to pull the shifter bezel
First oil change what oil sinister 2011-2014 Mustang GT 48 08-18-2014 07:57 AM
manual transmission oil change Torchredfrankie Pre-2005 V6 Mustang 13 02-03-2013 12:33 AM
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 11:37 AM
Who wins? 2008 v6 manual vs. 92 mustang lx 5.0 manual. wc3john The Bar 1 06-23-2011 07:10 AM
06:42 AM
