Can I use a common ring connector @ battery - Mustang Evolution
Old 03-26-2014, 09:44 AM   #1
Red89's Avatar
Question Can I use a common ring connector @ battery
I am in the process of cleaning up under the hood for show season. I was looking at my battery terminals and I have multiple ring connectors on each side.
Positive battery cable has these ring connectors:
1) battery tender
2) MSD box
3) electric fan lead (high amp)
Negative battery cable has these ring connectors:
1) battery tender
2) MSD box
3) Autometer electric gauge grounds for oil pressure and water temperature.
Would it be ok to connect all of the positive & negative feed wires to a common ring connector for a single, clean connection? This way I have only have 1 connector to each side of battery. I would obviously get a large gauge terminal and heat shrink after crimping.
Thanks,
Steve
Red89 is offline   Reply With Quote
Old 03-26-2014, 09:52 AM   #2
5.oh's Avatar
You can do that as long as you make sure everything has a good connection.
Sent from my SM-N900T using Mustang Evolution mobile app
5.oh is offline   Reply With Quote
Old 03-26-2014, 09:55 AM   #3
Red89's Avatar
I would solder the three leads together and then crimp them in an 8 gauge ring terminal as well as heat shrink the end of it.
Think it would be ok?
---------- Post added at 11:55 AM ---------- Previous post was at 11:55 AM ----------
Old 03-26-2014, 02:42 PM   #4
5.oh's Avatar
Yep, You got the right idea. It'll be fine as long as you have it all hooked up with good connection. You won't have a problem
Old 03-26-2014, 08:27 PM   #5
slade95gt's Avatar
Gotta make sure it's solid on both ground and power ..... Power is only as good as the ground it gets and vise versa
slade95gt is offline   Reply With Quote
Old 03-26-2014, 11:06 PM   #6
5.oh's Avatar
try something like this....
NOCO/Top post battery terminal end (TZ110CS) | Battery Terminal End and Adapter | AutoZone.com
you can hook whatever you want to this..then use a wire loom down the positive battery wire with all your other wires in it too make it look good.
What Oil Filters TO Use, And Not To Use JROC General Car Discussion 10 02-24-2007 08:19 AM
Cant buy common sense... Bane- The Bar 10 02-27-2006 09:42 AM
DAMMIT, I know the post office is slow, but common... 03redfire cobra The Bar 2 07-04-2004 11:20 AM
09:35 PM
