Lightweight driveshaft before my gears? - Mustang Evolution
Old 03-26-2014, 09:37 PM   #1
Splogan's Avatar
OK, so I decided to rehab the 95 and not toss it. I have to put in a TOB when the weather gets nicer. That exploded into a lot of parts. New TOB, stage 2 clutch, Flywheel, adjustable clable, quadrand, new hardware, new transmission retainer. I figured What the hell and even got a new exhaust since the old had to come off while working, why not put new back on.
My question is, since the drive shaft is coming off is it worth getting the ford racing aluminum one or spend the cash on new gears and say piss on the drive shaft.
1970 Mustang Fastback (Primer Gray)
1995 Mustang GT Convertible (Deep Forest Green)
2005 F-150 SCAB (Arizona Beige Metallic)
2016 Mustang GT, Fastback Perf Pack (Ingot Silver)
Splogan is offline   Reply With Quote
Old 03-26-2014, 11:08 PM   #2
5.oh's Avatar
i do not have any exprience with the aluminum drive shaft but gears make a big diffirence in the way the car launches and feels.
5.oh is offline   Reply With Quote
Old 03-27-2014, 06:50 AM   #3
If your stock driveshaft is not vibrating or giving you any issues its a complete waste of money to replace it.
Old 03-27-2014, 07:10 AM   #4
Splogan's Avatar
I do have vibration at speed but I have no clue if it is the drive shaft or something else. She is no spring chicken anymore
Old 03-27-2014, 07:11 AM   #5
mystang50's Avatar
I love my alumn driveshaft!! the weight diff is crazy
Old 03-27-2014, 07:22 AM   #6
It could be the DS or a U joint or the harmonic balancer or a rim or a tire. I mean you are saving weight with an aluminum DS and it could potentially cure the problem but its not exactly smart to just huck parts at a problem when you aren't sure what part is bad.
Old 03-27-2014, 04:13 PM   #7
Roguestang's Avatar
Gears are much more bang for your buck. Even if its your u joints, its probably cheaper to get them replaced than a FRPP driveshaft. 300 bucks for a minimal weight reduction is the last thing I would do. And btw I have one, got it used for 120 bucks when my u joints went bad and the drive shaft broke. I didn't notice a single difference with it on.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 03-27-2014, 04:47 PM   #8
5.oh's Avatar
i know that you could also use a aero star drive shaft. there aluminum and cheap at a junkyard. just make sure you get it balanced first cause they use fork lifts sometimes to lift and move the cars witch can damage the driveshaft... new yokes, used aluminum driveshaft, and balanced at about 150 dollars probably.
Old 03-27-2014, 05:08 PM   #9
I would do the repairs to the clutch first then drive it to see if that solved any of the vibration issues. Like Scotty posted check out a few things first. 5.0s are know for rubber internals failing on the balancer. I would do the gears first if your stock driveshaft is in good condition. The driveshaft wouldnt fall off my list I would just move it a little further down. What gears do you have, if I remember correctly the 2.73 and 3.08 cars have an external weight attached to the rear end, you can check it also.
Bigshow14 is offline   Reply With Quote
Old 03-27-2014, 05:23 PM   #10
slade95gt's Avatar
I have a balanced aluminum driveshaft from ford racing and 3.73 gears if I could pick only one of those id toss that f***ing driveshaft in the ditch....... I've noticed minimal difference if any..... And this is on a 95....... Gears are the way to go man
slade95gt is offline   Reply With Quote
Upgrade Your Weak Stock Driveshaft with The Driveshaft Shop at AmericanMuscle AMWill AmericanMuscle 1 03-16-2014 02:18 PM
Lightweight flywell Luna1994 2005-2010 Mustang GT 2 07-31-2013 02:20 PM
Lightweight Driveshaft Recommendations? FenixBirdWind 2005-2010 Mustang GT 11 12-28-2009 10:27 PM
09:43 AM
