Help me please - Mustang Evolution
Old 04-03-2014, 03:54 PM   #1
kyle_rivas's Avatar
Help me please
I need some help I just recently purchased the I think its called a bezel or something its the speedometer thing the white one and I took everything off but idk what do I need to do im am already at the gauges but I cannot pull out the hole dash piece and I cand take off the speed part idk what to do please help me.
galaxy s4
kyle_rivas is offline   Reply With Quote
Old 04-03-2014, 04:27 PM   #2
FullyAutomatic's Avatar
Region: Mexico
post pictures if you can, not exactly sure what your trying to do
FullyAutomatic is offline   Reply With Quote
Old 04-03-2014, 05:46 PM   #3
kyle_rivas's Avatar
This im trying to install it but I can't seem to get the other piece of its connected to something but I know there's a way to get it off or just a way I'm really confused
galaxy s4
Old 04-03-2014, 05:47 PM   #4
kyle_rivas's Avatar
This
galaxy s4
Old 04-03-2014, 05:53 PM   #5
Region: Mexico
are you asking how to remove that bezel? the whole thing... .. take the screws surrounding it out then pop the bizz out... if u have a new one anyways use a screwdriver if u need and pry a bit just be careful
Old 04-03-2014, 06:51 PM   #6
kyle_rivas's Avatar
I just orderd the thing where it says 140mph its just like a little paper strip but idk how to do it
galaxy s4
Old 04-03-2014, 07:11 PM   #7
slade95gt's Avatar
An overlay...... You need to take the plastic shield off u have to take out the bezel to do this there will be clips around it jus get a small flathead but be very careful
slade95gt is offline   Reply With Quote
Old 04-03-2014, 07:16 PM   #8
kyle_rivas's Avatar
galaxy s4
Old 04-03-2014, 07:19 PM   #9
kyle_rivas's Avatar
http://m.americanmuscle.com/reverseg...ge-8789v8.html please click that link and tell me how this would work
galaxy s4
Old 04-03-2014, 08:40 PM   #10
94GT302's Avatar
I believe the way those work you have to take the needles off your stock gauge cluster and then the new ones you just purchased just glue or stick over the factory ones.
---------- Post added at 08:40 PM ---------- Previous post was at 08:39 PM ----------
Then install the needles back on
94GT302 is offline   Reply With Quote
Old 04-03-2014, 09:20 PM   #11
kyle_rivas's Avatar
But is there a certain way to take the needles off because its a pain
galaxy s4
Old 04-03-2014, 11:04 PM   #12
94GT302's Avatar
I honestly haven't removed the needles before but I'm pretty sure you just pull on them
Old 04-04-2014, 08:25 AM   #13
kyle_rivas's Avatar
I tryed to pull them off but then they didn't come off and I uave looked everywhere and there is no video on how to do it
galaxy s4
Old 04-04-2014, 06:31 PM   #14
ALMOST STOCK's Avatar
Needles:
If you have to remove the needles (with some white face gauge installs you do and others you don’t)
If you do have to remove the needles make a drawing of the exact placement of the needles before you remove them<<< read that once more.
If you have to remove the needles and your kit didn’t come with some sort of needle removal tool you can use a regular dinner fork and slide it under the needle (did you make a drawing of where that needle was??) and gently pull or pry upward and the needle will release from the spline.
The only critical needle that you need to watch out for is the speedometer needle because it has a spring and will uncoil once you remove the needle. The spring helps hold the needle against the pin so that the needle will not bounce.
That’s about it the rest is installing the new white face gauge face, put the needles back on there splines exactly as per drawing that you made earlier noting the exact location of the needles, recoiling the spring behind the speedometer so that it rest against the pin, and clean the inside of the lens cover (the cover will scratch easily so watch what material you use to clean and wipe the lens with). If you have any burnt out instrument gauge light how would be a good time to replace them before you reinstall the instrument cluster back in the car.
ALMOST STOCK is offline   Reply With Quote
Old 04-05-2014, 09:13 PM   #15
94GT302's Avatar
Nice write up
Old 04-05-2014, 10:52 PM   #16
kyle_rivas's Avatar
I agree man that was good and a perfect help out I appreciate it a lot man thanks
galaxy s4
Please help me! Please!! 98StangKid SVT Mustang 0 05-17-2013 09:40 PM
PLEASE, PLEASE HELP!!! Zoe 2005-2010 V6 Mustang 6 03-11-2012 01:19 PM
MT82 Transmission Issue...Please Read and Please HELP DannyDoright 2011-2014 V6 Mustang 5 03-02-2012 08:46 AM
Sold a Car Please, please help!!? booth General Mustang Discussion 9 03-20-2010 09:29 AM
00 mustang gt radio help!!PLEASE HELP! ride0909 Mustang Audio & Video 1 01-13-2010 08:18 AM
03:32 AM
