Burnt clutch - Mustang Evolution
Old 04-18-2014, 06:51 AM   #1
Burnt clutch
I don't know what to do I just burnt out my stock clutch i have only had my 92 5.0 for about a week.i am the second owner guy before me installed e303 cam bbk short tube headers and bbk h-pipe and hi-flo cats would it be a waste to put a oem stock clutch or invest in a stage 2 or 3 and if yes why.. Money is not a issue
red vert 5.0 is offline   Reply With Quote
Old 04-18-2014, 06:57 AM   #2
Name:	ImageUploadedByMustang Evolution1397825857.984171.jpg
Old 04-19-2014, 11:57 AM   #3
slade95gt's Avatar
Just with those upgrades an oem clutch wouldn't hurt....... If money's not an issue though go with a stage 2 it's a lot firmer and more responsive
slade95gt is offline   Reply With Quote
Old 04-21-2014, 11:54 PM   #4
Thanks so I could go with a oem cuz I don't think I could wait any longer to drive her
Old 04-22-2014, 12:56 PM   #5
slade95gt's Avatar
Sure but I'd recommend an adjustable clutch cable
Old 04-22-2014, 01:01 PM   #6
Adogg's Avatar
Personally would get a stage 2 or 1 so you have room for later on if you ever do more modding. And it will feel a lot better.
Don't hate....... appreciate
Old 04-22-2014, 03:49 PM   #7
What else should I do it's my first car I have my truck I only know k&n and flowmasters. LolClick image for larger version
Name:	ImageUploadedByMustang Evolution1398203336.724090.jpg
Old 04-22-2014, 03:56 PM   #8
Adogg's Avatar
Others is so much you could do just depending on what you want to spend. I would say with the mods now maybe do gears 3.73 or 4.10 w.e you prefer short throw shifter. Are you running stock heads? If so you could do a set of gt40 heads and Intake upper and lower if your running stock there too. Then maybe some cosmetic mods such as tinting things and new wheels and tires.
Old 04-22-2014, 03:59 PM   #9
I love the pony wheels but I do want the cobra rims I can't tell a bout the heads and its s stock intake manifold I don't want a 8 second car more like a weekend warrior lol
Old 04-22-2014, 06:33 PM   #10
slade95gt's Avatar
I love my svt rims
Old 04-23-2014, 11:32 AM   #11
Adogg's Avatar
Yes cobra rims are great I have them on my 94. And even with the mods I told you, your car will still be a very nice street drivable car and won't be making insane power at all. If you drive a lot then go with 3.73 gears. And these gt40 heads and intakes can be picked up cheap and pretty much everywhere. Just put some money into the head replacing and cleaning everything and the same with intakes. If you ever do all that if your car should then be put on the dyno to get a tune then she will be running mint.
Old 04-23-2014, 11:42 AM   #12
But the guy I got it from said it had 4.10 gears do I have to count tho bolts on the diff or what hiw do I cheak
Old 04-23-2014, 11:45 AM   #13
Adogg's Avatar
Lol no need to count the bolts. If you have them already then you should know does your car really take off really hard at a stop? If you want you can count the rotations. Just look up a how to video on how to check gear ratio.
Old 04-23-2014, 12:01 PM   #14
From a whole the car diggs and takes off
Old 04-23-2014, 03:32 PM   #15
ALMOST STOCK's Avatar
How to Calculate a Rear Differential Gear Ratio
ALMOST STOCK is offline   Reply With Quote
Old 04-23-2014, 04:30 PM   #16
Thanks
Old 04-26-2014, 10:05 AM   #17
Hey dude how can I tell between a explorer intake or stock
Old 04-26-2014, 12:43 PM   #18
The Explorer intake will have a finned plenum the Stock intake is smooth.
Old 04-26-2014, 02:08 PM   #19
smurf stang's Avatar
Also you speak of stage 1, 2 or 3 but that means nothing as not all manufactures use those models.
A decent little clutch is the King Cobra clutch and will hold decent power.
Also upgrade you clutch cable, quadrant and adjuster so no more burning of clutches.
2016 VW GTI 2.0 Turbo
Old 04-27-2014, 02:34 PM   #20
Thanks for clearing that up but I think iam going stock iam not looking for more hp I got a three month old I can't get into that now many next year lmao
Old 05-03-2014, 11:40 AM   #21
I notices u have the cobra rims on ur foX I found some on eBay but iam not sure how to put them on my 92 do I have to change something
Old 05-03-2014, 02:14 PM   #22
The rims I have on my 89 are SSR Integral A2 rims 17 X 9 produced by SSR Performance not the Cobra Rims.
All you need is a 5 lug conversion with the 94/95 spindles in front and a 5 lug conversion in the rear and you should be able to run the Cobra Rim on your 92.
If you don't already have the 5lug conversion front and rear this will tell you what you need to do.
87-93* Ford Fox Body Mustang Brake Upgrades
ID:	155770   Click image for larger version
Old 05-03-2014, 05:15 PM   #23
M3no956's Avatar
Just so you know a clutch won't give you more power
M3no956 is offline   Reply With Quote
Old 05-03-2014, 06:50 PM   #24
Old 05-04-2014, 03:02 PM   #25
But smoother shifts and it can handle more power
Old 05-07-2014, 06:21 PM   #26
BloodRedStang's Avatar
the only definitive, sure fire way to tell your rear end gearing is to take the diff cover off and count the teeth on the ring and pinion gears. I thought my 91 had 3,73s based off the tire/ driveshaft rotations and when I had to take the rear end apart, I counted the teeth only to find out it was 3.08's.
BloodRedStang is offline   Reply With Quote
Burnt wires 93slowstang 1979-1995 Mustang GT 16 11-30-2011 07:49 PM
restore yellow burnt headlights cheap 1988_gt_5.0 General Mustang Discussion 10 10-15-2011 03:24 AM
Burnt Rice 04MonteSS The Bar 32 04-22-2005 04:59 PM
neighbors house burnt down this morning fast64 The Bar 10 10-11-2004 12:27 PM
09:55 PM
