Foxbody needs help!! - Page 2 - Mustang Evolution
Old 04-27-2014, 01:51 PM   #36
ALMOST STOCK's Avatar
Originally Posted by Shifty 5.0 View Post
Would like bad grounds to the engine cause something like this? And if so where would they be?
sometimes rev real high and stay there till I shut the car down
Rereading what you originally posted... that doesn't sound like a ground problem .
ALMOST STOCK is offline   Reply With Quote
Old 04-27-2014, 01:54 PM   #37
Do you have any diagrams or pictures of where to look for a bad wire or ground?
As far as a bad wire that could be any place but I have a complete list and diagram of most the ground locations for an 89 if you want them?
Old 04-27-2014, 01:56 PM   #38
Shifty 5.0's Avatar
Yes please any info would help because I cannot figure out what's wrong
Shifty 5.0 is offline   Reply With Quote
Old 04-27-2014, 02:00 PM   #39
Give me a few minutes and I'll post those for you.
Old 04-27-2014, 02:11 PM   #40
Hopefully these helps some.
Old 04-27-2014, 03:33 PM   #41
Shifty 5.0's Avatar
Do y'all think the fuel pressure regulator could be bad?
Old 04-27-2014, 07:43 PM   #42
5.oh's Avatar
Could. Take the line off the top and see if there's any gas in it. Check the iac for the idling problem. That's what I'd do first. Make sure it's not all clogged up with carbon and ****. Replace that if necessary, that should help. Then I'd check the tps voltage and make sure it's around .97-.98.
Sent from my SM-N900T using Mustang Evolution mobile app
5.oh is offline   Reply With Quote
Old 04-27-2014, 09:30 PM   #43
Shifty 5.0's Avatar
The iac is brand new and do you check the hose while running hot or when it's off?
Old 04-28-2014, 10:12 AM   #44
smurf stang's Avatar
Almost stock has every diagram known to man.
Way too go.
2016 VW GTI 2.0 Turbo
Old 04-30-2014, 08:35 PM   #45
5.oh's Avatar
Check it while it's hot and off.
Old 05-01-2014, 05:55 PM   #46
Shifty 5.0's Avatar
Okay so the other day I pulled my car in the garage running fine and let it sit for a day and then that night I took off my 1" phenolic spacer because I thought it could be a vacuum leak put the intake back on the lower with gasket bolted it down and now the car doesn't want to run! Like it backfires and will fire 1 cylinder every like 4 seconds and smells like a ton of gas! Then I swapped distributor and it didn't change anything!
Old 05-01-2014, 08:19 PM   #47
5.oh's Avatar
Change the tfi. Make sure your timing is rite also
Old 05-01-2014, 08:28 PM   #48
Shifty 5.0's Avatar
Already did that lol I fixed it somewhat but what cause the little backfire at idle?
Old 05-01-2014, 08:33 PM   #49
Shifty 5.0's Avatar
Already did that lol I fixed it somewhat but what cause the little backfire at idle ?
Old 05-01-2014, 08:34 PM   #50
Sounds like a good terminal cleaning of dizzy will help
txffmike is offline   Reply With Quote
Old 05-01-2014, 08:47 PM   #51
Shifty 5.0's Avatar
Old 05-02-2014, 05:13 PM   #52
5.oh's Avatar
Timing can do it also
foxbody
foxbody newbie thinking of taking to the strip... tips advice help!!! Sawyers15 1979-1995 Mustang GT 7 02-12-2013 10:16 AM
Please help my Foxbody Derak 1979-1995 Mustang GT 2 02-22-2009 12:46 PM
Help....Friend of mine needs a ride to the hospital BlkStang4Me The Bar 25 06-11-2004 11:58 PM
Atlast! Dom needs help. Dom Mustang Audio & Video 2 05-22-2004 11:30 PM
audio noob needs help Monkey Mustang Audio & Video 21 11-23-2003 08:57 PM
08:03 PM
