t5 to auto swap...whats all needed? - Mustang Evolution
Old 05-01-2014, 01:26 PM   #1
Hey guys thinking about going auto in my notchback. its a 92 5.0 currently with a t5 thats going bad. I hear turbos love automatics in these cars, whats all needed to swap with the trans? new driveshaft, crossmember? and do you need a computer from an auto car? Just seeing if anyone has done it on this site.. any info welcome. thanks!
92 lx notchback 5.0 5 speed gt40 upper/lower intake, windsor Sr. heads, trickflow cam, 39lbs injectors, pro m mass air, etc, 70mm turbo pushing 7lbs tuned w/ sct chip...
boosted92notch is offline   Reply With Quote
Old 05-01-2014, 05:08 PM   #2
Which auto trans do you want to use?
Bigshow14 is offline   Reply With Quote
Old 05-01-2014, 08:40 PM   #3
Automatic, pedal assy, converter, cables, trans cooler, automatic yoke for DS (or an auto DS), harness and PCM.
Honestly I'd recommend a 4R75w out of an 04 with either a manual valve body and shift it yourself or a Bauman US Shift to control it. Hit up Click Click Racing - Click Click Racing for more info, you'll get all the info you need there.
2000 Mustang GT Steeda #0048
Old 11-30-2014, 08:07 PM   #4
If it's a stock auto u just need fly wheel torque converter tranny cooler lines and trans just did oppiset swap and all u need to do is move hangers on exhaust depending I factory drive shaft is same
---------- Post added at 02:07 AM ---------- Previous post was at 02:07 AM ----------
And either take pedal off or new assembly what Evers eaiser lol.
goosetoff is offline   Reply With Quote
Old 11-30-2014, 08:08 PM   #5
Ok that's two necros, going through my user CP will it be three? Also there is more to it than that especially going TO auto.
Old 11-30-2014, 10:13 PM   #6
Just saying u don't need a different drive shaft I didn't need a new one so why should he ? Not necroing anything if can save him buying a ds if he do t need it right so relax not bashin u
Old 12-01-2014, 06:57 AM   #7
Its all good, and yes bumping a 7 month old thread is a necro but w/e lol. You don't need a new driveshaft itself but you do need the yoke, they are different between the stick and the auto.
Off the top of my head to do the swap one needs:
- Auto yoke
- Flexplate
- Converter
- Trans (duh)
- Shifter
- Shifter/kickdown cables
- Trans cooler
- Cooler lines
- Auto computer/harness or a standalone controller or a full manual valve body
If I was doing an auto in a fox I would do what I said in my first post from May. 4R trans with a standalone or a manual valve body with a brake.
Old 12-01-2014, 07:30 AM   #8
Ya I was only saying that because I never changed my yoke I used same one from auto to 5 speed
Old 12-01-2014, 07:34 AM   #9
Only things I needed was just pedals clutch flywheel and pressure plate and clutch cable didn't change computer why I don't no I see lots of people saying need to change lots of stuff why didn't I have too ? U know ur stuff and can u tell me why I didn't have to change any of that dosnt that seem weird to you
Old 12-01-2014, 08:25 AM   #10
I'm talking about going TO auto, not the other way around. Its easier to to to 5 spd than to auto.
Old 12-01-2014, 10:25 PM   #11
Ya but the drive shaft should be the same should it not
Whats needed to install aftermarket radio Slow4V Mustang Audio & Video 3 09-07-2013 11:27 AM
Auto to Manual advice needed Bily Pepp 1979-1995 Mustang GT 7 10-10-2012 08:24 PM
Whats Needed mcdonaldnick 1979-1995 Mustang GT 6 06-27-2012 10:07 PM
Whats all needed to lower my stang ? F4m0usfr34k 2005-2010 Mustang GT 5 03-17-2012 01:35 AM
whats the better rpm curve?/whats a good car choice? Thomas91169 The Bar 7 12-05-2003 11:24 PM
11:11 PM
