Heater core bypass - Mustang Evolution
Old 05-05-2014, 11:23 AM   #1
regattabluefox's Avatar
Heater core bypass
Just installed electric fans, aluminum radiator, 68 degree thermostat, 3G alternator. Everything's running smooth except my heater core appears to be leaking. Is the best or easiest way to bypass to just pull one end off at the firewall and reattach one single hose connecting both metal lines coming from the intake? I'm at work now and will be sitting in traffic going home. Looking for a way to assure I'm not gonna be stuck on the side of the road.
regattabluefox is offline   Reply With Quote
Old 05-05-2014, 07:14 PM   #2
ALMOST STOCK's Avatar
The metal heater tubes are 2 different sizes the inlet tube is 3/4" and the outlet tube is 5/8" so you just can't take one of the hoses and bypass the heater core.
You can drive your car even if the heater core is leaking you won't run out of coolant unless you're going to drive a couple of hundred miles with that leak from the heater core.
I suggest to drive home and if you find a Autozone or Napa Auto on your way stop and get a U-Shaped hose that is 3/4"on one end and 5?8" on the other and the drive home and do the hose swap.
You can go to Auto Zone and buy hose number B87629, it’s about $8.00 cut about 1" off and it fits perfectly.
Or
Napa Item: Hose - Radiator Upper (U-shaped bypass hose)
Product Number: NBH10743
Price: 7.49
The parts number change occasionally but if you ask for a U-shaped hose 3/4" on one end and 5/8" you've got the hose that you need to do the heater core delete.
ALMOST STOCK is offline   Reply With Quote
Old 05-05-2014, 08:04 PM   #3
foxbox's Avatar
Man, I took a piece of electrical conduit and cut it about 3 inches and then hose clamped the two hoses together with the conduit and it worked flawlessly for months until I found time to install a new heater core. No joke, its not a big deal. An 1/8” can be compensated for with tight enough hose clamps. Actually, its was a conduit elbow that was cut a few inches. Ill post a pic if I can find it.
foxbox is offline   Reply With Quote
Old 05-06-2014, 08:20 AM   #4
I ended up getting a piece of PVC that was 5/8-3/4 and just clamped em together. Made it home in traffic with no problem. I mainly just didn't want it to really blow out when I was in traffic. It was just a small leak but I didn't know how it was gonna act yet with the new electric fans.
Old 05-06-2014, 11:21 PM   #5
5.oh's Avatar
They make nipples like that to bypass it. I had to do it to mine when all my coolant was disappearing.
Sent from my SM-N900T using Mustang Evolution mobile app
5.oh is offline   Reply With Quote
Heater core... Z06 eater 1979-1995 Mustang GT 1 10-14-2011 09:18 PM
Heater core *sigh* 5.slow 1979-1995 Mustang GT 21 09-25-2011 07:34 AM
Heater core replacement! AAstang 1996-2004 Mustang GT 2 03-09-2011 05:31 PM
2001 mustang heater core bypass? Tye General Mustang Discussion 4 03-25-2010 04:39 AM
Heater Core steedav6builder Pre-2005 V6 Mustang 0 08-05-2004 11:36 PM
01:45 PM
