Thermostat gasket - Mustang Evolution
Old 05-06-2014, 07:40 AM   #1
Varasios's Avatar
Thermostat gasket
Hey dudes,
I keep on having a problem making a good seal,
Ive tried with RTV on its own.
Ive tried with an oem gasket on its own.
Ive tried with oem gasket and a bit of RTV.
Can someone give me their thermostat gasket 101, thanks
I hate coolant everywhere!
Varasios is offline   Reply With Quote
Old 05-06-2014, 02:51 PM   #2
smurf stang's Avatar
Well first off you gotta make sure that the surfaces are clean, flat and in good shape.
Secondly what water neck are you using?
Third I have had luck with just the gasket or just rtv but never both at the same time.
Make sure you let it cure the correct time.
2016 VW GTI 2.0 Turbo
Old 05-06-2014, 03:01 PM   #3
Varasios's Avatar
Waterneck is off a 93 engine
Old 05-06-2014, 03:11 PM   #4
Then make sure all surfaces are very clean and straight.
Make sure the tstat doesn't move around, main reason for leaks.
Do not over tighten......not sure of the torque specs right now.
Old 05-06-2014, 04:05 PM   #5
Varasios's Avatar
25 ft lbs
---------- Post added at 06:05 PM ---------- Previous post was at 06:05 PM ----------
Thanks dude
Old 05-07-2014, 12:24 PM   #6
Glad you got it figured out.
Upper intake plenum gasket and EGR gasket McNassty General Mustang Discussion 1 06-08-2012 10:51 AM
Is a valve gasket the same as a valve cover gasket? birtingr General Mustang Discussion 6 03-15-2010 02:24 AM
Thermostat 97conv6 Pre-2005 V6 Mustang 18 06-13-2005 06:41 PM
thermostat housing Warfire80 1996-2004 Mustang GT 14 09-16-2004 11:00 AM
Thermostat Laser02 Pre-2005 V6 Mustang 14 07-08-2004 02:08 AM
» Members Mustangs
SGM
BigCiv
ANGIE
BC13
Add your Mustang
01:54 PM
