Help please - Mustang Evolution
Old 05-11-2014, 01:54 PM   #1
kyle_rivas's Avatar
Help please
Last night I finally installed everything on to my 1989 Mustang gt and soon as I poured my antifreeze in the frount I thought I was all finished until I saw that it was leaking around the water pump area and thats the only thing preventing me to start my car someone please reply if you have any idea whats going on
galaxy s4
kyle_rivas is offline   Reply With Quote
Old 05-11-2014, 02:07 PM   #2
ALMOST STOCK's Avatar
My 1st thought is.....are all the bolts tight and then I'd move to the gaskets .. did they seal ...is it bent , or damaged? Did you install the backing plate on the back side of the water pump and are those 2 bolts tight and did you use a new gasket there?
ALMOST STOCK is offline   Reply With Quote
Old 05-11-2014, 03:02 PM   #3
kyle_rivas's Avatar
Im pretty sure everything is correct do you recommend taking everything apart? Should I call someone? What would you do if you had this problem?
galaxy s4
Old 05-11-2014, 03:23 PM   #4
I'd start off by drying things up with a towel, paper towel or air whatever it takes to get the area dry and check and see where the leak is coming from that way you should be able to find the cause of the leak. If that doesn't work then you'll need take things apart and find the cause of the leak.
Old 05-11-2014, 03:40 PM   #5
kyle_rivas's Avatar
But I cant really get under there to see what it is unless lifting it up lets me
galaxy s4
Old 05-12-2014, 09:30 AM   #6
smurf stang's Avatar
Do what almost said.......dry, then clean, then inspect.
Check the gasket and retorque to make sure all is ok. Pretty simple then if not we move onto the next round.
2016 VW GTI 2.0 Turbo
Old 05-12-2014, 10:33 AM   #7
kyle_rivas's Avatar
Idk why its doing that its dripping on the top of the water pump and making a pile of liquid then drips and leaks half ways empty do you think lifting the car would help I cant take everything off by myself its hard to get the belt off by myself but I will blow dry and get some light and figure this out
galaxy s4
Old 05-12-2014, 01:23 PM   #8
It shouldn't be hard at all to remove the belt. All you need is a 12 MM socket and a breaker bar... slip the 12 MM socket over the bolt holding the tensioner pulley on and lift upward in a counter clockwise direction. This will release the tension on the belt and then remove the belt the belt.
Old 05-12-2014, 06:38 PM   #9
kyle_rivas's Avatar
I know that but the problem is the belt is super tight but thanks a lot for the information I have my mechanic here he found the problem or I did but hes helping
galaxy s4
Old 05-13-2014, 07:41 AM   #10
What was the caused the leak?
The belt shouldn't be that tight, there is a belt wear indicator on the tensioner and you should be within that range.
Old 05-13-2014, 03:51 PM   #11
kyle_rivas's Avatar
It was a wrong bolt I had hell fixing it but I finally got it I put a couple washers and it stoped dripping right away
galaxy s4
Old 05-13-2014, 04:09 PM   #12
Yep......... a wrong bolt will do it every time.
Old 05-13-2014, 05:36 PM   #13
And what about the belt?
Old 05-13-2014, 05:52 PM   #14
kyle_rivas's Avatar
Just being negative lol didn't think I could do it but all I had to do was take off some hoses and get to it
galaxy s4
Old 05-14-2014, 01:43 PM   #15
Well there ya go, on the road to becoming a little man.
Ya broke your cherry.
Old 05-14-2014, 02:50 PM   #16
kyle_rivas's Avatar
Lmao not yet man I need to get me a bumper
galaxy s4
My 92 mustang died please help please wont start HybridTruth93 1979-1995 Mustang GT 2 05-04-2014 03:07 PM
Please help me! Please!! 98StangKid SVT Mustang 0 05-17-2013 09:40 PM
PLEASE, PLEASE HELP!!! Zoe 2005-2010 V6 Mustang 6 03-11-2012 01:19 PM
MT82 Transmission Issue...Please Read and Please HELP DannyDoright 2011-2014 V6 Mustang 5 03-02-2012 08:46 AM
Sold a Car Please, please help!!? booth General Mustang Discussion 9 03-20-2010 09:29 AM
03:34 PM
