Please help one headlight dim one bright!!! - Mustang Evolution
Old 05-14-2014, 05:02 PM   #1
Ok so I have a 93 mustang lx it has brand new headlights and bulbs yet the bulb on the passenger side is dimmer than the drivers side both on dim and bright setting. I'm not the greatest with electrical issues and I haven't found a solution on any forum I have checked all the ground wires that I'm aware of anyways and can not think of anything else. So to sum it up does anyone know what my problem is?
jpounders5.0 is offline   Reply With Quote
Old 05-14-2014, 06:26 PM   #2
Have you swapped the bulbs yet just to make sure its not the bulb? If not it sounds like it is a wiring issue somewhere or you might have a weak alternator. Or it could be a bad ground. Remember, your car is a classic in many states already, if the grounds have never been maintained they corrode and ALWAYS cause problems. Foxes also are notorious for the alternators going out. Even if your alternator isn't bad its a good idea to upgrade to a 3G.
Old 05-14-2014, 06:58 PM   #3
already checked all grounds, have a 3g alt. already, new battery, not sure what else it would be!
Old 05-14-2014, 06:59 PM   #4
So you did swap the bulbs or no?
Old 05-15-2014, 05:37 AM   #5
Yes new bulbs and headlights both
Old 05-15-2014, 05:44 AM   #6
No, I'm asking if you took the dim bulb and swapped it physically to where the bright bulb is or vice versa to make sure you did not get one bad and one good bulb. That would be the first step to troubleshoot this. After that, I would start tracing wires back towards the firewall.
Bright Atlantic Cobra :: 1998 Ford SVT Cobra Rosco Member Garages 0 11-12-2012 11:58 AM
Tag lights Bright White 2003SonicBlue Mustang Paint, Appearance & Detailing 9 02-23-2012 05:31 AM
1989 mustang need help dim light 1987mustanglx50 2.3 Mustang 4 01-27-2012 01:31 AM
Lights dim when my electric fan comes on Blackedout Pre-2005 V6 Mustang 8 04-08-2011 09:31 AM
My 2000 Bright Atlantic Blue Coupe in for repair and new paint job wyldpny Pre-2005 V6 Mustang 14 11-19-2009 05:44 AM
03:31 AM
