Motor mounts! - Mustang Evolution
Old 05-14-2014, 05:33 PM   #1
regattabluefox's Avatar
Motor mounts!
Just noticed today my motor mounts are done. Don't even know how it's still under the hood. Any tips on how to get it done in a timely manner?
regattabluefox is offline   Reply With Quote
Old 05-14-2014, 06:23 PM   #2
As far as what? Motor mounts are stupid easy to do, undo the big nut under each of them that holds the mount to the K member, jack the motor up via the pan with a block of wood between the jack and the pan and support with jackstands. Then just remove each mount and replace with a new one, re-install the nuts once you drop the motor back down and you are good. Replace the grounding strap on the driver's side while you are at it.
Old 05-14-2014, 06:54 PM   #3
smurf stang's Avatar
BAMN and Bob's your uncle.
2016 VW GTI 2.0 Turbo
Old 05-19-2014, 10:30 AM   #4
Cool. Only thing I was trippen off was wether or not id be able to lift it from the pan. I don't have a cherry picker. Any recommendation on a certain motor moumt? Was thinking if just the solid ones from late model restoration.
Old 05-19-2014, 12:22 PM   #5
Solid ones will transmit a lot of vibration. A lot of guys use the stock vert mounts. Energy suspension poly ones are good too. Watch out for Prothane ones, the Prothane mounts raise the motor up higher than stock which means you can run into driveline vibration issues.
Old 05-19-2014, 06:46 PM   #6
Boys on point.....Bam bam bam.
Old 06-24-2014, 07:09 PM   #7
I did end up going with the solid ones. Took about 45 minutes to replace with the help of my buddy. Vibrations not to bad. It's really only noticeable passed 4500 rpm, so while getting on the freeway you can definitely feel it. At lower rpms though it just sounds and feels like part of the exhaust. It spins both wheels more than before though, I noticed that while leaving for the test drive. When I can get the motor rebuilt though it will probably get the vert ones knowing what I know now. The solid ones were half the price though and at the time money was an issue. Appreciate the input
Motor mounts Berbantor 1996-2004 Mustang GT 7 10-30-2011 07:32 AM
Help with motor mounts mlaytonsr1 1996-2004 Mustang GT 4 07-13-2009 03:44 PM
06:43 AM
