Vacuum leak question - Mustang Evolution
Old 05-15-2014, 03:51 AM   #1
Varasios's Avatar
Have a 93 gt engine with e7 heads, 1,7 svo rockers, stock injectors, stock MAF,
70mm edelbrock tb and elbow, trick flow intake upper and lower manifolds,
Mac shorties, bbk cai, msd pro billet dizzy, mad 6al2 box
Originally set it so car idles at 900rpm,
When the engine gets to temp and I either drive it or rev it, the engine only comes back too 1100rpm..
I was told this is the sign of a vacuum leak and to use the propane from a torch to find the leak.
Whatcha guys think?
Thanks.
Varasios is offline   Reply With Quote
Old 05-18-2014, 09:27 AM   #2
Varasios's Avatar
Old 05-18-2014, 09:59 AM   #3
It's not me, it's you.
primer2tone's Avatar
Yeah, you can try that. I've always just used starting fluid. But most of the times I've had idle problems in a ford, it's been the idle air control valve.
Old 05-19-2014, 09:07 AM   #4
Varasios's Avatar
Thanks for the help dude
Old 05-19-2014, 11:37 AM   #5
Varasios's Avatar
Def thinking its the iac valve,
Propane didnt get it to rev up.
Gonna try cleaning the iac up with carb cleaner
Old 05-19-2014, 12:07 PM   #6
Site Sponsor
Sponsor
AMWill's Avatar
I'd guess it has something to do with the IAC malfunctioning too. While you're cleaning it up, you might as well pick up some MAF cleaner and clean that as well. It's probably not the lead cause of your problem, it could amplifying the issue if the MAF is dirty.
Good luck and let us know how you make out!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 05-19-2014, 06:50 PM   #7
smurf stang's Avatar
Run your codes also.
2016 VW GTI 2.0 Turbo
Old 05-25-2014, 05:02 PM   #8
Hellish Horse's Avatar
Pull the Air line off your Master Cylinder & Blow Cigar smoke through it. If you have a Vaccum leak the smoke will come out of the leak.
Hellish Horse is offline   Reply With Quote
Old 05-25-2014, 07:26 PM   #9
Varasios's Avatar
Monte?
Cohiba?
Og kush?
Lol
Old 05-25-2014, 09:39 PM   #10
Take your pick !!! Something I learned on U-Tube & it works.
Old 05-26-2014, 03:37 AM   #11
Varasios's Avatar
Sounds good dude,
Thanks for the help.
Boss Manifold Vacuum leak JMDoll 2011-2014 Mustang GT 18 03-23-2018 05:24 PM
Vacuum leak 88ShiftyFifty 1979-1995 Mustang GT 5 03-29-2013 10:54 PM
Vacuum leak? 1986gt 1979-1995 Mustang GT 2 03-22-2013 04:03 AM
Erratic Idle problem solved-Intake manifold vacuum leak Mercedez L. 1979-1995 Mustang GT 7 07-30-2010 09:08 AM
How do you fix a vacuum leak on a 1977 mustang cobra? giovanni Classic Mustangs 5 08-17-2009 02:02 PM
08:08 PM
