Noise after new suspension - Mustang Evolution
Old 05-15-2014, 07:46 AM   #1
It have recently put lowering spring in my 1990 fox body. Now everytime I go over a bump I hear the rubber isolators or the spring and it annoying. I have taken it apart and adjusted springs still same noise. Anyone out there got some suggestions
derf666 is offline   Reply With Quote
Old 05-15-2014, 10:23 AM   #2
ALMOST STOCK's Avatar
You mention adjusting the springs, did you orient the pigtails in the correct position?
ALMOST STOCK is offline   Reply With Quote
Old 05-15-2014, 10:35 AM   #3
Pretty sure instruction told me to leave the drain hole open on the a arm so the pigtails are a quarter inch from the end of the socket
Old 05-15-2014, 11:39 AM   #4
I'll assume that you installed the spring insulators top and bottom of the springs?
Old 05-15-2014, 11:40 AM   #5
Put in new isolators if you didn't already.
Old 05-15-2014, 12:19 PM   #6
New poly urethan one got installed with the springs
Old 05-15-2014, 12:41 PM   #7
Poly makes noise. If you don't want noise, replace with rubber.
Old 05-16-2014, 12:25 PM   #8
10-14 before and after pics after mods gtstyles2 Mustang Paint, Appearance & Detailing 16 08-27-2013 02:45 PM
2001 v6 3.8 engine noise after new belt truckdriver0 Pre-2005 V6 Mustang 6 01-03-2013 09:03 PM
Spinning noise after clutch install. sam13708 1979-1995 Mustang GT 8 08-31-2012 10:37 PM
Metal squealing noise after driving for a while Patches89 1979-1995 Mustang GT 11 08-20-2012 06:09 PM
1968 6cyl Noise after highway drive gdoyle05 Classic Mustangs 13 07-08-2011 08:24 PM
06:22 AM
