What's the best motor to swap in a fox? - Mustang Evolution
Old 05-17-2014, 05:20 PM   #1
Shifty 5.0's Avatar
What's the best motor to put in a fox? I'm thinking about a 351 or 331 Stroker but want to know some other opinions
Shifty 5.0 is offline   Reply With Quote
Old 05-17-2014, 07:01 PM   #2
ProudSixxer26's Avatar
Termi swap!!!!
ProudSixxer26 is offline   Reply With Quote
Old 05-17-2014, 07:17 PM   #3
Shifty 5.0's Avatar
Let's be realistic lol I'm talking best bang for your buck pushrod
Old 05-17-2014, 08:55 PM   #4
What's ur budget?
Old 05-17-2014, 09:40 PM   #5
Explorer motor. Supercharge, 425-450 to the wheels.
If you are talking about strokers "bang for your buck" means do you want to get 600 to the wheels NA for $8k or 600 to the wheels for $10k?
If you DO do a stroker or any NA buildup for that matter use a 351 based platform. Your "bang for you buck" is light years ahead of the 302 and you don't need to invest $2k in a DART block to get past 500hp. A street friendly 408 stroker will do 500+ to the wheels without really trying all motor. Keep a 200 shot in reserve for track days or ******** who bother you.
Old 05-18-2014, 11:08 AM   #6
Shifty 5.0's Avatar
What do you guys think about a blueprint 408 Stroker? It would be EFI
Old 05-18-2014, 01:43 PM   #7
Best possible way to go. Get ahold of Woody at FordStrokers.com 331-347-408-418-427 Custom Built Small Block Ford Engines
There is no better place to get pushrod parts/advice from than there.
Old 05-18-2014, 01:53 PM   #8
Rapinator126's Avatar
LS swap it.
Old 05-18-2014, 02:11 PM   #9
Originally Posted by Rapinator126 View Post
LS swap it.
That's another option.
I have half a mind to do it to my 98 if I keep it. I'd have to see all what is involved as far as electronics. I hear its not very difficult at all and plenty of ppl make swap K members.
Old 05-18-2014, 02:29 PM   #10
Yes its verry simple especially if you go carbed.
Its simple. 2 swaps. Either do a coyote swap or a LS swap.
Old 05-18-2014, 02:48 PM   #11
Probably the same price honestly when all is said and done if you factor in tossing a cam or a HCI at a LSx.
For a 408, some TFS 205 or 225 Hi Ports, custom cam and a good intake to match and that's a 500-600hp motor.
Old 05-18-2014, 02:53 PM   #12
Coyote with. Cobra jet Mani. Full exhaust. Heads / cams, full Bolton's. And e85 will be 520-550 at the tires.
Old 05-18-2014, 03:42 PM   #13
Shifty 5.0's Avatar
I'd Love to do a coyote swap but by the time you put all the money in needed to do the swap you could get way more horse from a Stroker or something else
Old 05-18-2014, 04:26 PM   #14
If it's a daily driver stick with the 408. The 408 is a good all around engine. You can't beat going with the coyote but price for the 5.0, wiring, k-member, etc gets expensive. And the lsx engines are great also, but leave that for the bow tie cars. Ford has to many good engine choices to justify cross breeding your car.
Bigshow14 is offline   Reply With Quote
Old 05-18-2014, 04:33 PM   #15
Coyote or LS that's it. Everything else is just wannabe
Old 05-18-2014, 04:43 PM   #16
Shifty 5.0's Avatar
I will never put a Chevy motor in my Mustang... I'm most likely going to go with a 408 what's the best clutch to handle that power? And will the whole T-5 have to be rebuilt to handle it?
Old 05-18-2014, 04:50 PM   #17
408 and get drugg by a 302
Old 05-18-2014, 05:07 PM   #18
Eh... at some point in modding engines are more TFS/AFR/Edelbrock than Ford/Chevy. Uh, yeah ANY transmission behind a 408 is going to need a build. If you want to stick with a 5 speed get an Astro A5. I'd go auto with a 408 personally.
Eh... good 408 with a proper setup and a nice auto shifting the whole thing is an undiluted can of rape on wheels. Not in the same league as your 1400whatever HP LSX but not much is honestly lol.
Old 05-18-2014, 05:11 PM   #19
A spec clutch set to match your hp/trq and after a few good lauches on sticky tires the stock t5 will eventually die. It will last you awhile if you run regular street tires until you upgrade the t5.
Old 05-18-2014, 07:07 PM   #20
Lol it is overkill.
I think a nice coyote swap in a fox would be nice though. Plus a little spray and you would be set.
The LS motors just sound so dam good though. A nice ls7 swap in a coyote would be sick 👍
Old 05-18-2014, 08:48 PM   #21
smurf stang's Avatar
Best off going with a 351 stroker or even simpler would be a turbo 351.
2016 VW GTI 2.0 Turbo
Old 05-18-2014, 08:53 PM   #22
No... nothing is simpler about a turbo app vs a NA app... There is 0 point in any power adder but nitrous in a stock blocked 351 based stroker. The blocks top out around 700-750hp and a good high compression one setup properly will be in the 550-600hp range all motor no problem. Just keep a shot of the sauce on tap if you ever need that extra 150-200hp.
Now if you have a DART, that is a totally different ballgame. Then again, you can buy a LS1 motor for not much more than just a DART block not to mention if you take a gander over into Modular land the stock blocks here will support 4 figure HP no problem and we have aluminum AND they are cheap. My Teksid and OEM forged Cobra crank was $250 picked up.
Old 05-18-2014, 08:59 PM   #23
Nitrous for the win 👍
What fox body motor to buy? Sybesma07 1979-1995 Mustang GT 18 10-24-2012 06:37 AM
Whats the best motor oil to use on my fox body mustang? fnam 1979-1995 Mustang GT 3 12-20-2011 11:50 AM
questions for a 98 - Driver Seat motor, Headlights, and window motor StreetJMusic Pre-2005 V6 Mustang 10 06-27-2011 03:39 PM
hot to tell the dif between PI motor and reg motor Keto77 1996-2004 Mustang GT 13 07-29-2009 12:03 AM
Project Fox Continues - The motor is out PureVenom Pictures and Videos 12 03-31-2008 11:37 AM
12:43 AM
