Diff. Tooth contact pattern - Mustang Evolution
Old 05-17-2014, 05:47 PM   #1
94_2valves's Avatar
How can there be no pattern shown here but the pinions teeth are painted? What I miss?
Name:	ImageUploadedByMustang Evolution1400370298.425451.jpg
ID:	157081Click image for larger version
Name:	ImageUploadedByMustang Evolution1400370357.864702.jpg
94_2valves is offline   Reply With Quote
Old 05-17-2014, 08:45 PM   #2
You've got to do more than lightly roll the gears. Does look like a slight pattern towards the outside edge.
How did you set pinion depth?
Sent from my massive johnson.
Old 05-17-2014, 09:01 PM   #3
94_2valves's Avatar
Starting to think that the guy I had press the bearing on only used one shim I have em. Was gonna add up to .030. Should of just used the oe shim
Old 05-18-2014, 07:27 PM   #4
94_2valves's Avatar
What shim size would you start with for 3.55? .030?
Old 05-18-2014, 09:10 PM   #5
If you put in ford gears it should have a number to add or remove from a base of .030. The frpp 4.10's I just put in my car called to add .01.
Old 05-19-2014, 03:21 PM   #6
94_2valves's Avatar
Sorry to keep bothering.. What would you say to that pattern?
Name:	ImageUploadedByMustang Evolution1400534460.326533.jpg
Old 05-19-2014, 04:54 PM   #7
I'm no expert but that looks pretty good.
Speedo gear 19 tooth 98 auto v6 daniel95 Pre-2005 V6 Mustang 2 09-07-2013 11:58 PM
A broken tooth. Patrick Pre-2005 V6 Mustang 12 03-15-2011 09:13 PM
Ghetto Tooth Fairy at7311 The Bar 14 09-27-2006 08:46 PM
Items for sale for a friend....Look @ Contact Info KrazyPony Mustang Parts for Sale and Wanted 0 01-26-2004 06:17 PM
10:18 PM
