Weird Oil Pressure Issue - Mustang Evolution
Old 05-22-2014, 09:09 PM   #1
New to the forum! New to 5.0s! Thanks in advance!
So normal driving, oil pressure is great. It is very steady around 60 psi. But under heavy acceleration, the oil pressure slowly drops. It does not drop to zero but goes pretty low to about I would say 20 psi. As soon as you take your foot out of it, it goes right back to normal. Factory gauge.
Here are the particulars on the car: 89 LX 5speed. I just bought this car a couple of weeks ago. It looks like an aftermarket block but its hard to tell. Was told it is a 306 with forged pistons at minimum. TFS heads, X303, original cobra intake with 70mm throttle body, Vortech V1, Aftercooler, FMU, T-Rex booster pump, MSD 6AL BTM, BBK Long tubes, off road h-pipe, mac 2.5 cat back. When I bought it, the car was way over the previous guys head. It had a wicked vacuum leak that was the plenum gasket and it ran like total crap so I never pushed it hard. That is till today after I fixed all that.
Thoughts?
PWR SHFT is offline   Reply With Quote
Old 05-23-2014, 02:41 PM   #2
smurf stang's Avatar
Factory gauge is doodoo.
Unfortunately a good aftermarket one would dispel any concerns.
2016 VW GTI 2.0 Turbo
Old 05-28-2014, 05:52 PM   #3
Factory gauge? There's your problem. The factory gauge is not accurate in any way shape or form whatsoever. You need a good aftermarket gauge to have any idea what your actual PSI is.
Weird electricsl issue pony_dogg 2005-2010 Mustang GT 7 01-07-2013 09:07 AM
weird pulling issue nosympathy 2011-2014 Mustang GT 36 11-20-2012 05:06 PM
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 11:37 AM
fuel line pressure vs rail pressure Sirtat 2005-2010 Mustang GT 2 01-10-2012 05:03 PM
OMG.. WEIRD.. so weird.. wiarumas The Bar 14 02-17-2005 12:45 PM
09:21 PM
