Help Purchasing new IAC for my Fox - Mustang Evolution
Old 05-23-2014, 09:41 AM   #1
ivan88GT's Avatar
The other day my car started to idle pretty high when started, I say a little over 2000 rpm. Did some reading on forums so I most certain I need a new IAC. My question is should I get one at my nearest autozone for 61.99 (dura last) or one off LRS for 59.99 (oem) or invest 20 bucks more and get a motor craft one off LRS? Does it even matter? To me the oem one off LRS looks good but I just wanted some opinions. Thanks
ivan88GT is offline   Reply With Quote
Old 05-23-2014, 02:28 PM   #2
smurf stang's Avatar
Well personally I would try cleaning it. Then I would also clean my MAF.
Finally I would check for a vacuum leak to really rule out the IAC.
Spend some time before you start spending money.
Also run your codes and see what pops up.
2016 VW GTI 2.0 Turbo
Old 05-23-2014, 02:33 PM   #3
ivan88GT's Avatar
I cleaned both those things, I will have to check for any leaks.Thanks.
Old 05-25-2014, 07:00 PM   #4
ivan88GT's Avatar
What do you think on those three IAC
Old 05-26-2014, 09:36 AM   #5
Latemodel should be fine.
Old 05-26-2014, 11:31 AM   #6
RockAuto Parts Catalog
Get the Hitachi or the Motorcraft.
New to Forum...purchasing 2012 GT Brembo Thriller 2011-2014 Mustang GT 37 05-04-2013 05:39 AM
Purchasing Help! >>>>> 2013 V6 tgmeyer 2011-2014 V6 Mustang 9 04-21-2013 06:47 PM
purchasing a 2nd Mustang need help! v8herturk 2011-2014 Mustang GT 19 12-30-2011 05:09 PM
Question about purchasing a new car? breandan General Car Discussion 2 08-17-2009 08:02 PM
purchasing through ebay cypress Mustang Wheels & Tires 6 02-11-2004 04:59 AM
02:07 AM
