Quad Shocks - Mustang Evolution
Old 05-25-2014, 09:20 PM   #1
Davesorl04gt's Avatar
Quad Shocks
Thought while I had the car on stands that I would change the struts and rear shocks. Advanced told me the quad and rear shocks were the same. They are not! Do the quad shocks ever go bad since they are not under the same load as the rear shocks?
Davesorl04gt is offline   Reply With Quote
Old 05-25-2014, 09:23 PM   #2
Roguestang's Avatar
Most of those guys wouldn't know what a car was if they got hit by one. And yes they can go bad like any other shock. Take em off and check the rate of compression and expansion. But if they've been on there a while, it would never be a bad idea to replace them.
1990 Mustang GT w/ Vortech V3
***resident gun idiot***
Old 05-25-2014, 09:32 PM   #3
Originally Posted by Roguestang View Post
Most of those guys wouldn't know what a car was if they got hit by one. And yes they can go bad like any other shock. Take em off and checl the rate of compression amd expansion. But if they've been on there a while, it would never be a bad idea to replace them.
Your right. Bought the shocks online to get a discount. Used the tech support for the question on fitment. Guess tech support is not much better than counter help. After I take them off and compress them what should I look for? Feel or how long it takes them to expand?
Old 05-25-2014, 09:47 PM   #4
Roguestang's Avatar
Both. Feel for sure, and make sure they expand at a decent, steady rate.
Old 05-26-2014, 11:50 AM   #5
...throw them in the garbage...
Sent from my massive johnson.
Old 05-26-2014, 12:26 PM   #6
Install a set of aftermarket LCAs and toss them. They are unnecessary once you upgrade the garbage lowers.
Old 05-26-2014, 02:36 PM   #7
Roguestang's Avatar
Although I would generally agree, they're not completely useless. Some still need them to limit wheel hop even with good quality LCA's like MM or Steeda. I even kept mine after putting MM lca's on. I would recommend if the OP does decide to put some lca's on, keep those quads around and see if you like it or not.
quad shocks FullyAutomatic 1996-2004 Mustang GT 7 04-05-2014 08:41 AM
Quad shocks Iowaboy13 Pre-2005 V6 Mustang 1 05-14-2013 09:02 AM
Quad shocks jwhayne0001 1979-1995 Mustang GT 9 09-19-2011 08:32 PM
Quad Shocks tire Pre-2005 V6 Mustang 1 07-22-2003 08:48 AM
quad shocks x 2 tire Pre-2005 V6 Mustang 2 07-20-2003 07:33 PM
10:27 AM
