Rear Brake Rotors wont come off...Help Plz. - Mustang Evolution
Old 05-26-2014, 11:36 AM   #1
Hellish Horse's Avatar
OK... I got most of my motor problems figured out so I'm trying to do the Brakes & Suspension / Bushings while the motors being built.
I started out by trying to do the Rear Shocks & Brake Rotors. Shocks...No Problem !
Rotors...Got Me ??? Can't get them off.
The Calipers & Brackets Have been removed. I even took off the Dust Plates behind the rotors so I could see better. I cant find anything holding the Rotors on.
There are No Wavy Retainer Washers on any of the Lug Nuts holding it on.
I've changed rotors on a few other Mustangs in the past & they always slid right off.
I've tried banging it pretty hard with a mallet ...didn't budge it.
Tried using a 3-Jaw Puller...didn't budge it.
Not sure what the problem is. It looks as if the rotors & calipers have never been touched before. The car is a 94 Mustang GT / 5.0 so it appears to have 20 years on it with no service to this area.
The Center Hole in the Rotor & the Hub Assembly look as if they're one piece they're so rusted as well as the holes for the Lugs & the Lugs. Looks like a lot of Rust in there. The Rotors Look like a Wavy Potato Chip & the Pads were almost to the Metal so it definitely needs to be changed.
I've sprayed it with PBR several times but it doesn't seem to be doing much as of yet.
Is there anything I'm missing that could be holding the rotors on other then rust ?
Can I just beat them off with a hammer or what ???
THX !!! for any help .
Hellish Horse is offline   Reply With Quote
Old 05-26-2014, 11:44 AM   #2
Hammer and time
Sent from my massive johnson.
Old 05-26-2014, 11:50 AM   #3
That's kind of what I was thinking.
Old 05-26-2014, 12:30 PM   #4
You can use a nut and a bolt in the caliper bracket to "press" it off. You put the bolt through the caliper bracket hole with the nut between the rotor and the bracket. Thread the bolt though the nut and start to tighten. The nut will press against the inside of the caliper bracket and just keep turning the bolt till you break the "seal" on the rotor.
Also a BFH will work.
2000 Mustang GT Steeda #0048
Old 05-26-2014, 02:40 PM   #5
Used the ole 5-lb Sledge. Worked like a charm. Less than 10-min. per side. Took my Drill w/ a
wire wheel & got all the rust off everything & now it's ready to put back together when I get the energy. Arizona Heat just drains you working outside. Probably put it together tonight or tomorrow. No hurry...got 2 cars.
Old 05-27-2014, 07:25 AM   #6
Yeah eff the heat. It was 75 degrees Friday when I did my transmission. In the heat... no thanks.
Old 05-27-2014, 05:11 PM   #7
Yeah...For Sure !!! Been outside trying to finish the job but it's too HOT !!! 108 today & it aint nothin nice !!!
Old 05-27-2014, 05:15 PM   #8
Yeah that is hot. Worst I've ever been in is 130 over in the desert working on aircraft. That is 15 minutes outside and 45 in the AC... most work gets done at night. When it is still in the 90s lol.
Brake lights wont come on caulderk 1996-2004 Mustang GT 14 05-15-2014 01:43 PM
Plz plz calling all mechs. 95 5.0 durtyred69 1979-1995 Mustang GT 12 01-20-2012 10:09 PM
Engine shut off and wont start Help plz?!? SonicBlueGT9963 1996-2004 Mustang GT 29 11-02-2011 10:14 AM
Rear rotors on an 02, cant get them off Myles 1996-2004 Mustang GT 10 01-04-2011 06:37 PM
Stock Front Brake Calipers & rotors off a 2002 V6. runvsofthisbull Mustang Parts for Sale and Wanted 0 05-27-2009 06:20 PM
» Members Mustangs
Maxeen
Mystic96
Tonka
Borii
Add your Mustang
04:45 AM
