Heater core line - Mustang Evolution
Old 05-26-2014, 02:23 PM   #1
Ohdang1990's Avatar
Heater core line
I no longer have a heater core and I want to delete the line that runs to it but there's just one problem, there's a sensor and a hose running to it. Does anybody know what that sensor is and will it be ok the cap off the hose that runs from the water pump?
Ohdang1990 is offline   Reply With Quote
Old 05-26-2014, 03:01 PM   #2
ALMOST STOCK's Avatar
Sounds like you're talking about (ECT) Engine Coolant Temperature Sensor.
You can get a NPT reducer at Home Depot that is 1/2" to 3/8".. Screw the reducer into where the heater tube use to be and then screw the sensor into the reducer.
Then cap off the line from the water pump to the old sensor.
ALMOST STOCK is offline   Reply With Quote
Old 05-26-2014, 03:24 PM   #3
Ohdang1990's Avatar
Thanks a lot!
Old 05-27-2014, 08:14 PM   #4
Now would be a great time to add an aftermarket sensor as well. If you don't want a dead gauge in your cluster you can get a F-150 filler neck that has a water temp sensor port in it and stick the stocker in there so they both work.
Heater core help! Elfman 1996-2004 Mustang GT 8 12-15-2011 02:18 PM
Heater core... Z06 eater 1979-1995 Mustang GT 1 10-14-2011 09:18 PM
Heater core *sigh* 5.slow 1979-1995 Mustang GT 21 09-25-2011 07:34 AM
Heater core replacement! AAstang 1996-2004 Mustang GT 2 03-09-2011 05:31 PM
Heater Core steedav6builder Pre-2005 V6 Mustang 0 08-05-2004 11:36 PM
11:49 PM
