SN95 Fuel Rail ? - Mustang Evolution
Old 05-30-2014, 08:03 PM   #1
Hellish Horse's Avatar
SN95 Fuel Rail ?
Will 87-93 Mustang 5.0 or Explorer 5.0 fuel rails fit & work on a SN95 Mustang 5.0 with GT40 Explorer Heads ( Not P's) or are the fuel rails specific to the 94-95 5.0's ?
Also...are the 87-93 Alternator / Smog Pump / Tensioner Bracket & the P.S. Pump / A.C. Bracket the same or different then the 94-95 Brackets ?
These are the last few pieces I need to finish my motor so I need to find out what will work.
Hellish Horse is offline   Reply With Quote
Old 05-30-2014, 09:50 PM   #2
Brackets are different completely, that is one of the big reasons if you buy a supercharger you need a 94/95 specific kit.
94/95 rails are also different than the fox stuff. Having a 94/95 car can be frustrating as every damn thing is "87-93".
Old 05-31-2014, 01:31 PM   #3
smurf stang's Avatar
Scotty is correct.
Also exploder fuel rails are different.
2016 VW GTI 2.0 Turbo
fuel line pressure vs rail pressure Sirtat 2005-2010 Mustang GT 2 01-10-2012 05:03 PM
Remove fuel rail for spark plugs? ajpturbo 1996-2004 Mustang GT 5 06-14-2010 07:55 PM
96 fuel rail removal problem shustwit Pre-2005 V6 Mustang 1 08-11-2008 06:12 AM
Fuel Rail Suggestions mspHtown General Mustang Discussion 3 11-19-2007 11:47 AM
split port swap fuel rail immenukka Pre-2005 V6 Mustang 4 08-09-2007 10:40 PM
02:15 PM
