High Air/Fuel ratio - Mustang Evolution
Old 06-06-2014, 10:27 AM   #1
OneSlow95's Avatar
High Air/Fuel ratio
Recently my 95gt a/f ratio has been pretty high, it will range from anywhere between 15- 18, and its been going over 18 a lot more frequently. At idle it will jump from 14.5-17. Its naturally aspirated. Was curious to see if anyone else has had a similar problem. My best guess would be possibly dirty injectors? Maybe fuel filter needs to be replaced? I can't seem to find a straight answer online so far, thanks.
OneSlow95 is offline   Reply With Quote
Old 06-06-2014, 11:02 AM   #2
Site Sponsor
Sponsor
AMWill's Avatar
What wideband are you using to measure the Air/Fuel ratio with? How long as it been installed for and how long have you been using the same oxygen sensor for the wideband? Also, whens the last time it was recalibrated (if it can be calibrated)?
There's a really good chance the wideband is just not reading accurately for one of the several reasons above. Keep that in mind before looking for any mechanical issues.
Hope this helps!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 06-06-2014, 11:59 AM   #3
OneSlow95's Avatar
It's an AEM digital wideband, it came with the car. not sure how long ago, or if the sensor was ever replaced. I've had the car for about 3 months now, and not totally sure how to even go about re calibrating the wideband. ive done a couple mods here and there since ive got it, but nothing i can think of that would actually affect the wideband reading.
Old 06-09-2014, 02:04 PM   #4
smurf stang's Avatar
When are you getting this reading?
If this reading is from idle then it will raise and dip all the time. Your car also uses timing to help control the idle.
2016 VW GTI 2.0 Turbo
Old 06-09-2014, 03:30 PM   #5
OneSlow95's Avatar
Yeah I figured when idling, it would be all over the place, but its random all the time. Obviously at wot it stays more around 13ish but city driving and highway will be totally random
Sent from my SCH-I605 using Mustang Evolution mobile app
Old 06-09-2014, 05:50 PM   #6
That's normal then.
Old 06-09-2014, 09:16 PM   #7
OneSlow95's Avatar
Even though it will go past 18 for periods at a time? When I first got the car 3 months ago it never went past 18, now it frequently does it alot
Old 06-09-2014, 09:17 PM   #8
OneSlow95's Avatar
Old 06-10-2014, 09:48 AM   #9
Ok let's start from the beginning.
You got the car 3 months ago.....have you done:
A full tune up? Cap, rotor, wires, plugs, fuel filter (obviously not), clean the MAF, PCV valve and screen?
Run your codes? What came out?
What's your timing?
What's your fuel pressure?
Where is the wideband installed?
A lot of factors come into play than just a gauge with numbers.
How high is too high? Pirate Bman Pre-2005 V6 Mustang 8 06-23-2014 12:24 PM
The High, High Cost of Mstng Mods blu General Mustang Discussion 9 01-18-2014 04:11 PM
AIR/FUEL RATIO 94GT302 1979-1995 Mustang GT 4 04-01-2013 11:55 AM
Can anybody recommend a high horse power high torque engine? pueblo70 Classic Mustangs 4 08-21-2009 05:32 PM
help asap air/fuel ratio gauge install Rstang98 Pre-2005 V6 Mustang 8 03-06-2004 01:17 AM
12:19 PM
