Fender Modification? - Mustang Evolution
Old 06-11-2014, 10:51 PM   #1
Jinash's Avatar
Hey all, just installed a MM K-member & a-arms on my 90 GT and now can't even turn my wheels due to the longer wheelbase of the a-arm position. (Severe rubbing on front ground effect piece) Trying to run FR500's with nitto 245/40/18. Anyone run into a situation like this? I know the 91-93 fenders have a bigger opening but not sure if it's enough to alleviate problem?
Jinash is offline   Reply With Quote
Old 06-11-2014, 10:53 PM   #2
Jinash's Avatar
Here's a pic of how close wheel/tire is to front ground effect Click image for larger version
Name:	ImageUploadedByMustang Evolution1402548785.842320.jpg
Old 06-12-2014, 12:29 AM   #3
running 5.0's Avatar
Wow looks good but the rub sucks *** I'm running 40's low profile try a set of those poly urethane blocks in the springs.my son dropped his 96 a little lower than expected and put them in and he was happy.
Sent from my SAMSUNG-SM-N900A using Mustang Evolution mobile app
running 5.0 is offline   Reply With Quote
Old 06-12-2014, 08:44 AM   #4
91-93 fenders are noticeably wider and a very common mod for 90s and below running something like you are. Not sure if you got the regular or forward offset MM arm but you can get the ones that provide 0 movement with their K member. I'd try the fender first and if not then you'll have to eat the cost of the A arms and see what you can get selling the ones you have .
Old 06-12-2014, 02:59 PM   #5
smurf stang's Avatar
Does the MM kmember move the arms?
I know my UPR one kept the same geometry.
Got find out first.
2016 VW GTI 2.0 Turbo
Old 06-12-2014, 04:05 PM   #6
Its all on the MM site.
The regular setup moves them .75" forward, the forward offset arms move them 1.25" forward, the rear offset arms keep them in the same location.
The longer the wheelbase the better but then you can run into fitment issues as we can see here.
Old 06-12-2014, 05:22 PM   #7
Whoopsie.
Old 06-12-2014, 06:15 PM   #8
Jinash's Avatar
Thanks for all the replies guys, talked to MM and they say to keep the forward offset arms (I have the ones that move everything forward 3/4") looks like I'm in the market for a set of 91-93 fenders
2000 Mustang GT - Stock Hood Modification thesauceguru 1996-2004 Mustang GT 7 03-11-2009 11:58 PM
Need help with EFI harness modification for 64 1/2 mustang ballajb Classic Mustangs 3 10-29-2008 03:57 PM
V6 exhaust modification jonesarah New Member Introductions & Greetings 1 03-06-2008 02:58 PM
Free new modification for 05's!!!! "Coolent bypass trick" ricklmesa Pre-2005 V6 Mustang 10 10-28-2006 11:41 PM
AIR FILTER HOUSING MODIFICATION Donny B Pre-2005 V6 Mustang 1 08-20-2003 09:43 AM
03:25 PM
