Gas leak - Mustang Evolution
Old 06-14-2014, 01:11 PM   #1
JGS797's Avatar
Gas leak
i just bought a 1988 5.0 and whenever put gas it leaks for a day or two but I only notice it when its parked. what could I do to fix this
JGS797 is offline   Reply With Quote
Old 06-14-2014, 02:17 PM   #2
Shifty 5.0's Avatar
You will need to find the leak to successfully be able to fix the problem.
Shifty 5.0 is offline   Reply With Quote
Old 06-15-2014, 04:18 AM   #3
Hellish Horse's Avatar
My 94 Leaked when I bought it. It was the Rubber Grommet that connects the filler neck to the tank. Not real hard to change if that's where your leak is.
Hellish Horse is offline   Reply With Quote
Old 06-16-2014, 04:42 PM   #4
Liebert91stang's Avatar
I agree with hellish it's probably filler neck grommet if it's after you put has in it.there is another grommet that goes around fuel pump also.if you going to drop take mine as well replace both
Liebert91stang is offline   Reply With Quote
Old 06-17-2014, 09:06 AM   #5
smurf stang's Avatar
It is more like what Hellish said as it is a very common problem.
2016 VW GTI 2.0 Turbo
Old 06-17-2014, 10:54 PM   #6
UDLOOZ's Avatar
I had that issue on my 88. Real easy and cheap to fix
UDLOOZ is offline   Reply With Quote
Low gas mileage, gas leak and smell evan1989 Pre-2005 V6 Mustang 3 03-31-2014 11:08 PM
Possibly Fuel Leak, Gas Tank Mustang1804 1996-2004 Mustang GT 33 04-03-2010 09:46 PM
gas leak upton7 Pre-2005 V6 Mustang 7 04-20-2009 01:32 AM
2001 Cobra fuel leak (I know wher3e the leak is) badcrc General Mustang Discussion 2 12-27-2008 11:54 PM
Gas leak/Smell? runvsofthisbull Pre-2005 V6 Mustang 15 12-27-2008 04:58 PM
01:50 AM
