help with pulley - Mustang Evolution
Old 06-20-2014, 07:15 AM   #1
ricky1379's Avatar
help with pulley
i just bought a new power steering and installed it in my mustang but once i started the engine it tore up the belt and the pulley almost came off
Name:	ImageUploadedByMustang Evolution1403270086.224044.jpg
ricky1379 is offline   Reply With Quote
Old 06-20-2014, 12:06 PM   #2
Once they press on with that tool they shouldn't come off. Did you install it with the tool or just smack it on with a hammer? Also how did you remove it? If you yanked it with a claw puller you can bend it and then it'll never seat back on properly and tear up any belt that you put on.
Old 06-20-2014, 12:18 PM   #3
ricky1379's Avatar
i did use a pulley tool to take it off but to install it back i did use a hammer because i didn't have the other part of the tool to install it back....
i don't know wich tool is the right one to install it back
Old 06-20-2014, 12:27 PM   #4
It's the same tool, or it should be. You reverse a piece of the tool and it goes right back on. You could have perma damaged the shaft or the pump using a hammer, I dunno. At the very least you probably didn't get it on there far enough.
Old 06-20-2014, 12:41 PM   #5
ricky1379's Avatar
thank you i'm looking right now for the right tool so i can buy it and install the pulley
---------- Post added at 06:41 PM ---------- Previous post was at 06:40 PM ----------
by chance do you know wich one is it?
Old 06-20-2014, 12:42 PM   #6
You can just rent it at any box store like autozone or advance. Give them a CC, they swipe it and full refund upon you returning it.
Old 06-20-2014, 02:20 PM   #7
smurf stang's Avatar
Also make sure it is all lined up after the install just don't run it.
2016 VW GTI 2.0 Turbo
Old 06-20-2014, 02:37 PM   #8
ALMOST STOCK's Avatar
The install tool is completely different than the removal tool
The install tool threads into the nose of the PS pump and then pushes/presses the pulley on to the PS shaft.
The removal tool has two clam shell halves and threaded stud bolt .
Install tool ----------------------------------------- Removal tool
ALMOST STOCK is offline   Reply With Quote
Old 06-20-2014, 02:40 PM   #9
ricky1379's Avatar
ok the installer tool on the pic you sent eas too long and it didnt thread to the p/s shaft so i used a 3/8 bolt long enough and that did the trick but i still have to start the engine once i get the belt...if it goes
Old 06-20-2014, 02:42 PM   #10
ricky1379's Avatar
if the pulley goes out of the shaft again then what now?
Old 06-20-2014, 03:29 PM   #11
I'd say that there is something wrong with either the PS shaft or the PS Pulley.
All I can say is on my 89 there was a 7/16 inch gap between the PS housing and the PS Pulley which made the belt line up correctly, I sure someone will have a better explanation of the correct alignment process.
Old 06-25-2014, 08:58 PM   #12
hey does anyone know how to install a a/c bypass pulley. i got no ****ing idea and looked on youtube couldnt find a video or a diy online. maybe someone can break it down dummy style for me to as iv never done this before. i shouldnt need a newer belt right. i do got under drive pullies. its for a 95 5.0 . thanks a million to. im changing it because its ****ed i got white smoke coming from it and its completly frozen. i dont use my a/c anyways. plus didnt want to spend hella $$$
italiantj88 is offline   Reply With Quote
Old 06-26-2014, 06:26 AM   #13
Every kit I've ever used has an adapter that makes it a universal remove/install kit. You can rent them for free from Autozone/Advance.
Old 06-26-2014, 05:01 PM   #14
ricky1379's Avatar
thanks i ended up using a 3/8 bolt with washer and nut and it worked
Old 06-26-2014, 07:48 PM   #15
What I posted was the tool that you could rent from AutoZone but instead of renting the tool I bought it from AutoZone for something like $12- $15 years ago.
Needing help with 2002 mustang belt tensioner/pulley. Aereth Pre-2005 V6 Mustang 11 06-14-2015 05:39 AM
Polished water pump pulley and alt pulley for 01-04 4.6 2v Everett Mustang Parts for Sale and Wanted 1 03-17-2011 02:52 PM
Bad Pulley? Please help. Dude87 1996-2004 Mustang GT 1 10-07-2008 08:51 PM
help with pulley install quick! MusclesFromBrussels Pre-2005 V6 Mustang 3 08-19-2003 05:58 PM
snapped bolt with underdrive pulley, need help and fast 062stang Pre-2005 V6 Mustang 0 07-16-2003 12:46 AM
08:18 PM
