What is this - Mustang Evolution
Old 06-25-2014, 04:42 PM   #1
kyle_rivas's Avatar
What is this
Can someone tell me wgat tgis is im pretty sure I know what it is but I want to make sure with you all doesn't need any more pieces or do I need something install it can I use it on my car?
galaxy s4
ID:	160060   Click image for larger version
kyle_rivas is offline   Reply With Quote
Old 06-25-2014, 04:55 PM   #2
ageless1's Avatar
It's a throttle body (not complete). You can use it on a GT but not a V6.
MBRP Pro Series 304 SS Axle Back
Color Matched Mirror Covers
PA660 4-Channel Amplifier
6x8 Rockford Fosgate Punch (Door Speakers)
6x8 Kicker CS68 (Rear Deck Speakers)
Infinity Basslink (200W Powered Sub, Trunk)
ageless1 is offline   Reply With Quote
Old 06-25-2014, 05:14 PM   #3
Eturner's Avatar
Don't think that is a TB!.. Looks like a MAF of some sort!..
Old 06-25-2014, 05:16 PM   #4
ageless1's Avatar
Could be that too but I think it connects to or is part of the tb. I know that 80mm is the size of a tb.
Old 06-25-2014, 05:29 PM   #5
It's a Mass Airflow meter.
Old 06-25-2014, 06:44 PM   #6
DaBluedude's Avatar
It's a MAF housing. Looks incomplete. Could it be used? Yes, is it going to be easy, not without reprogramming the computer. Would be a lot of work. Might be worth something to someone on eBay. But not a lot.
2003 Mach 1
Old 06-25-2014, 06:45 PM   #7
5.oh's Avatar
Yep, mass airflow piping. Sensor goes on top, says for 24 pound injectors
Sent from my SM-N900T using Mustang Evolution mobile app
5.oh is offline   Reply With Quote
Old 06-25-2014, 08:05 PM   #8
Its a MAF and its not from a Fox. Looks like a SN95 version. You'll need an adapter to put it into a fox intake tract.
This looks absolutely nothing like a TB btw...
Old 06-26-2014, 09:25 PM   #9
smurf stang's Avatar
So so so wrong.
Like the others said it is a MAF.
2016 VW GTI 2.0 Turbo
Old 06-26-2014, 11:15 PM   #10
kyle_rivas's Avatar
Does this mean that I cpuld use this if I have bigger tubing
galaxy s4
Old 06-27-2014, 01:03 AM   #11
Hellish Horse's Avatar
It appears to be an 80 mm MAF Sensor Housing off a SN95 Cobra 5.0 . It's for 24-lb. Injectors which were stock on the Cobra's. I have the same set up on my car.
BTW...T=Bodies come in many sizes & an 80 mm T-Body would be quite large. On 87-93 I believe T-Bodies are 60 mm Stock & 65 mm on SN95's.
Hellish Horse is offline   Reply With Quote
Old 06-27-2014, 10:31 AM   #12
No it isn't 94/95 Cobras shared an identical MAF to the GT which is a 75mm diameter but the post in the middle gives it something like a 70mm flow size. The 24lb injectors in the Cobra have nothing to do with the MAF as well, it is set for 19s just like the GT. The correct way to set the fuel tables for any MAF is in the tune anyway. "Calibrated" MAFs are basically hacked and not optimal at all. This is why you can't just plug a J4J1 Cobra computer into a GT and vice versa with the GT's T4M0 computer. They are set for different injector sizes.
So what that picture is is either:
-A stock housing with a "calibrated" element installed into it
-A stock MAF that someone thinks is for 24s because it came out of a Cobra
-Some stock looking 80mm aftermarket MAF with a "calibrate" element
Old 06-27-2014, 01:44 PM   #13
When I went to buy my MAF & Injectors the guy had a 94 or 95 Cobra & he told me that those were the stock parts off it. But who knows...maybe the guy he bought the car from changed stuff & he didn't know it. The MAF in the pic is identical to the one I bought...80 mm & all. Actually, I'm getting rid of the 80 & going to a C&L 73mm since my T-bodies a BBK 65mm. I think the 80 is a little big & makes my air intake set up almost whistle. Didn't do that when I had the 70mm MAF on the car. Then again...maybe one of the rubber fittings on the cai aint sealing good. Can't tell at idle as everything sounds normal then.
Old 06-27-2014, 02:32 PM   #14
Transfer tables ain't nothing to play with.
Old 06-27-2014, 04:14 PM   #15
Stock is not 80mm and there is no need to upgrade the 94/95 stock TB/MAF until you do either a HCI or (better and cheaper) a Vortech.
07:24 PM
