Mark VIII - Mustang Evolution
Old 07-04-2014, 10:44 AM   #1
Mark VIII
Hey Guys, I've seen a lot of modular Mark VIII swaps into the 96 and up SN95's and new edge mustangs, but i haven't seen much in the older pushrod 5.0's i have a couple of questions and would really appreciate it if anyone who has swapped the motor into an older pushrod 94-95 could maybe help me out, i'd really appreciate it thanks,
EricF945oh is offline   Reply With Quote
Old 07-04-2014, 08:00 PM   #2
Going to need an entire harness out of a 96-up car, also new cluster, new fuel setup, new trans and some other things. 96 was when they went to OBDII and the motors are completely different and the bolt pattern for the transmissions are different. The Mark VIII swap happens in the 96-up cars alot because they use the same motors, or at least the 4V is a 95% drop in for those cars since the 4V and 2V are both modulars. It is NOT an easy drop in for the 95-down.
The swap is typically done with a full donor car like a wrecked Cobra or something so you can take EVERYTHING you need. In all honesty I'd stick with the Pushrod but that's just me. You'll spend more money and time into doing the swap then you would selling your car and buying something that already has a 4V in it. Or even a clean 2V with a blown motor to swap a 4V into.
Old 07-05-2014, 08:11 PM   #3
Thanks, yea i have the whole 98 Mark VIII donor car and it is running, i figured it would be a lot, of work i think it would be easier if my car was a newer year model, i know it would be a lot simpler to do the swap, i had a 2002 gt and i did a 5.4 swap in that and it was pretty simple, but i might attempt it in the 94 being as how i have the whole car, thanks a lot for the info
Old 07-06-2014, 10:24 AM   #4
Well donor as I mean you should need a modular mustang as a donor, not the Mark VIII itself.
1998 lincoln mark viii 90fox Member Garages 1 06-06-2017 01:42 PM
WTB 2v, 4v cobra/mark, or a Mark VIII complete engine TopgearGT Mustang Parts for Sale and Wanted 9 12-19-2012 12:50 PM
Mark VIII swap? AgentOrange 1996-2004 Mustang GT 9 06-17-2012 11:38 AM
is the power steering pump from a 1997 Lincoln mark viii the same as the 1997 cobra Cobra209 SVT Mustang 2 05-04-2012 01:40 PM
My Lincoln Mark VIII Drawing ! challe Pictures and Videos 13 06-18-2005 03:29 PM
03:13 AM
