Overheating problem - Mustang Evolution
Old 07-07-2014, 10:13 AM   #1
kyle_rivas's Avatar
Overheating problem
Ok I have a 1989 gt pretty much stock have everything new pretty much rebuild and cleaned heads water pump e303 cam stocks rods roclers ect. Say I drive it about a mile or so just to where the motor is really hot and ya I feel as if it gets too hot but thats just me well then the water just shoots out everywhere like brown nasty water im thinking that I need to take it out and flush it? Or maby its because theres nothing but water in the radiator and a little bit of antifreeze because of a leak I used to have do I need a new radiator?? Fan or something and the thermostat is brand new so thats not the problem but maby someone could hook me up with some tips ideas concerns something that could possibly fix this issue thanks a lot.
galaxy s4
kyle_rivas is offline   Reply With Quote
Old 07-07-2014, 03:20 PM   #2
Hellish Horse's Avatar
Brown, Nasty Stuff ??? Sounds like a Blown / Leaking Head Gasket, Warped Head or Cracked Head. Probably a Head Gasket. Sounds like you got oil in your water. Does it look all nasty on the dipstick too ? If it is you more than likely have a blown head gasket.
Hellish Horse is offline   Reply With Quote
Old 07-07-2014, 04:31 PM   #3
smurf stang's Avatar
Brown yucky water just might be rusty crud
Overheating......did you install the tstat correctly?
Also you can go to Advanced or whatever and they will rent you for free a pressure tester and check out your cooling system.
2016 VW GTI 2.0 Turbo
Old 07-08-2014, 01:14 AM   #4
kyle_rivas's Avatar
No the gaskets are fine like I said everything is brand new I recently fixed the problem by flushing it out and ya it was probably dirty due to the blown head gaskets back then but now she seams to be running better with new antifreeze oh btw it says do not add water but I still do anyway
galaxy s4
---------- Post added at 06:14 AM ---------- Previous post was at 06:13 AM ----------
And can you you give me some more info about advanced auto because I might just do that?
galaxy s4
Old 07-08-2014, 01:37 PM   #5
Yeah they loan you a tool with a credit card as deposit and when you return they refund you the deposit. So it is free......
Loan-A-Tool | AutoZone.com
Help overheating problem Wheelieman618 1996-2004 Mustang GT 2 12-12-2012 09:30 PM
overheating problem Anthony8994 Pre-2005 V6 Mustang 14 10-19-2012 08:35 AM
Overheating problem My68mustang General Mustang Discussion 10 07-11-2012 05:00 AM
Overheating problem? Fast93Coupe 1979-1995 Mustang GT 1 07-01-2006 01:29 PM
Overheating problem NorwegianMustang Pre-2005 V6 Mustang 7 04-27-2005 03:52 PM
10:17 PM
