Car problems - Mustang Evolution
Old 07-09-2014, 09:53 PM   #1
SexiLilFox's Avatar
I have an 89 foxbody and been having issues with her. I been going up hills and gradual hills and even trying to get up to speed on the freeway. During all these things my car shutters real bad and doesn't pick up speed but she makes noise like something is knocking. If I am not on the accelerator she stops. Also another issues that happened was she sounded real bad and so I turned the key and took it out and she sounded like she was trying to start and the key wasn't even in. So I started her again and she sounded terrible but I let her run and then eventually I was able to take the key out and that had only happened once. What is wrong with my little girl? My boyfriend and I both think it may be my fuel pump and starter that are going out. What do you all think?
Thanks.
SexiLilFox is offline   Reply With Quote
Old 07-09-2014, 11:32 PM   #2
Shifty 5.0's Avatar
Sounds like your in extreme need of a tune up. Plugs/wires/cap
Shifty 5.0 is offline   Reply With Quote
Old 07-09-2014, 11:48 PM   #3
Is the check engine light on?
Yep. 25 year old car.... You're going to have to check EVERYTHING!
You may be on the right track though and this could be a fuel delivery problem. It may be as simple as a clogged fuel filter. I'd try that first.
The starter could be going bad also but the problem with the starter staying on is likely due to a failing starter solenoid.
Aren't old cars fun?
Old 07-09-2014, 11:57 PM   #4
SexiLilFox's Avatar
Yeah but I would never give her up for anything. The check engine light is not on. What would you recommend I do? Bring her to a mechanic and get a full expection done?
Old 07-10-2014, 12:07 AM   #5
I know exactly how you feel.
Yeah, you need a fuel pressure test guage to properly diagnose the fuel system so a mechanic might be your best bet. Your boyfriend might be able to do the fuel filter if you wanted to try that though.
And the solenoid is relatively easy to replace, you just need to disconnect the battery first.
Old 07-10-2014, 12:10 AM   #6
SexiLilFox's Avatar
Yeah. I might go get her checked out. I mean she is my daily driver and I love her very much. She is also my first car I have ever owned and is my baby. It makes me cringe every time I feel her shutter. So definitely gonna get her checked out tomorrow if I can since I won't be working. Also if the solenoid and fuel filter aren't too much I may just get that replaced too. But quick question, would it be worth it to just replace the whole starter instead of just the solenoid? What's your opinion on that?
Old 07-10-2014, 12:14 AM   #7
Well, you may have to replace both the starter and the solenoid since the starter was stuck on... That's VERY hard on the starter when that happens.
Old 07-10-2014, 12:17 AM   #8
SexiLilFox's Avatar
Yeah it freaked me out and scared me a bit. I mean she is my first car I have ever owned and I have also never heard a car do that. So I didn't know what to do. Very scary experience
Old 07-10-2014, 12:25 AM   #9
I have an F250 that's around the same "vintage" as your car and the same thing happened to it a couple years ago, it sucked!
I had to disconnect the battery to stop it...
Good luck with your car and let us know what you find out at the mechanic.
Old 07-10-2014, 12:26 AM   #10
SexiLilFox's Avatar
Yeah. I'll be sure to let ya know. As I said I am gonna see if I can get her in tomorrow.
Old 07-10-2014, 09:45 AM   #11
smurf stang's Avatar
Even if you don't have a cel or a check engine light on it could still have codes stored.
I would have them check it out.
Also if it has been a while or if you don't know if it has been done, yes a full tune up is a good idea.
2016 VW GTI 2.0 Turbo
Old 07-10-2014, 05:05 PM   #12
SexiLilFox's Avatar
Does anyone know where the fuel filter is located?
Old 07-10-2014, 05:45 PM   #13
Liebert91stang's Avatar
On the backside of the fuel tank up by the frame.easy change
Liebert91stang is offline   Reply With Quote
Old 07-10-2014, 06:23 PM   #14
SexiLilFox's Avatar
How do you know if the fuel filter is bad by looking at it?
Old 07-10-2014, 06:53 PM   #15
They need to be changed periodically.they are like 15 dollars or less.i change mine once a year
Old 07-11-2014, 07:29 AM   #16
If you have never changed since you got the car I would change it then.
Old 07-13-2014, 03:49 PM   #17
SexiLilFox's Avatar
Yeah then the fuel filter really needs to be changed
Old 07-13-2014, 04:05 PM   #18
Change the filter and run some fuel injector cleaner through it.
Old 07-13-2014, 04:05 PM   #19
SexiLilFox's Avatar
Okay
Old 07-19-2014, 01:11 AM   #20
racks2relax's Avatar
Check the rubber grommets that hold the throttle cables to the throttle body. My car would lag from 0-30 mph and pick up after. I found a worn grommet, changed it for a new one and it fixed the problem. Hopefully that helps
Sent from my SM-N900P using Mustang Evolution mobile app
racks2relax is offline   Reply With Quote
Old 07-19-2014, 01:14 AM   #21
Could the key problem be the ignition switch? Try replacing it, local auto store should have it for $25
« Help!!! | Fuel pump »
Problems and more problems BigB227 1996-2004 Mustang GT 1 08-22-2012 09:12 AM
car problems. Twit38 1996-2004 Mustang GT 7 06-20-2011 07:26 AM
Car Seat Problems a3705872 Pre-2005 V6 Mustang 6 10-04-2010 10:04 PM
Vortech supercharger problems car quits running sporter 2005-2010 Mustang GT 15 11-28-2008 05:55 PM
Car problems continue,Speedo' problem Dark02Pony Pre-2005 V6 Mustang 4 09-22-2005 12:19 PM
11:14 AM
