90 with 4.10 Gears and AOD tranny - Mustang Evolution
Old 07-15-2014, 01:40 AM   #1
racks2relax's Avatar
Meaby someone on here can help, originally wanted to swap a t5 into my 90 but had a hard time finding a legit WC t5, so I went ahead and installed 4.10 gears before i begin gathering parts to complete the swap. I didn't look much into the speedometer problem since I kind of knew it would just take a tooth to fix it, but turns out that late model fox body AODs and 4.10 gears don't mix well with speedometers. Wondering if anyone has found something that's worked well for them, i know the biggest tooth LMR carries is only a temporary fix.
Which brings me to my next question, if I install the tooth I've heard the teeth disintegrate, will it affect the tranny or just change the ATF?
Sent from my SM-N900P using Mustang Evolution mobile app
racks2relax is offline   Reply With Quote
Old 07-15-2014, 04:56 AM   #2
Liebert91stang's Avatar
Would have to change driveline to fix speedo.its machines into them
Liebert91stang is offline   Reply With Quote
Old 07-17-2014, 06:24 PM   #3
So I need to get a new driveline machined on?
Old 07-18-2014, 03:33 PM   #4
It should have an 8 tooth drive gear in it so if you got a 23 tooth speedo gear it should be close
Old 07-18-2014, 05:35 PM   #5
That's what I ordered last night! I've heard it'll fix it for at least a little over a year. But I don't daily drive it so it should last me longer. Will I run into a problem with it disintegrating? @liebert91stang
Old 07-18-2014, 08:01 PM   #6
Mine has 373 in it and got the 23 tooth gear.its still off.anything over that isn't a ford gear and will not last long.proobably just eat some teeth off.
1973 Ford Bronco 302 and AOD transmission question? wylingford Classic Mustangs 3 03-23-2010 09:44 PM
Would a 1987-1993 ford mustang 5.0L AOD tranny fit a 1995 ford mustang 5.0L engine? raimondo General Mustang Discussion 1 03-14-2010 01:37 AM
2000 mustang AOD tranny help yerg 1996-2004 Mustang GT 1 03-07-2010 06:02 PM
Rebuilt AOD stalls engine in reverse and only has 1st gear 91StangGT5.0 1979-1995 Mustang GT 5 11-12-2009 04:02 PM
AOD tranny question? mustang slizzy 1979-1995 Mustang GT 3 12-09-2007 09:00 PM
03:42 AM
